Show me your 1590A enclosures/pedals...
Started by andrew_k, January 29, 2008, 09:42:28 PM
stahoo8
Hi. Next project - Little Green Wonder.
pickdropper
I wasn't originally planning on boxing this one up as it was the PCB I built to verify the layout.  Since I am still waiting for the enclosure for the next one, I decided to box this one up.  That's good as I am probably going to tweak the etch a little bit.  The next one will also have the proper Ge diodes.
It's a mini version of the Riot.
stahoo8
jimilee
From another dimension:        Meanwhile, back on Planet Earth:
Seriously, great builds both!   ;D
pickdropper
Modified EA Tremolo w/bypassable LFO so that it can be used as a boost
poppyman
This batch  is ridiculously gorgeous! :O
peterg
Quote from: deadastronaut on March 03, 2014, 03:59:37 AM
+1  very nice.. 8)
+2. Pickdropper - is there a trim pot and exterior pot for adjusting the voltage?
pickdropper
Quote from: peterg on March 03, 2014, 02:20:32 PM
+1  very nice.. 8)
The trim pot adjusts the bias on Q2.  The external pot is a supply voltage sag for the entire circuit.  People seem to love their dying batteries.
Mustachio
Those are awesome Pickdropper! Neat look'n transistors too. The first fuzz face I built I did the voltage sag and mid control from GGG it sounded pretty nice.
Your overall designs come together so well.
"Hhhhhhhnnnnnnnnnnnnngggggggg"
Luke51411
1st 1590A build. Started out easy with a SHO. This was a fun build.
I'm just starting to try a 1590a sized box for some builds. no matter what the size of the box, and no matter how well planned and test-fitted I do, it never fails to amaze me the way the space just disappears before you've got everything in there! where the hell does it go?
..... and then you find you haven't planned for the screw that's going to come through the side to hold it all together .......
pickdropper
Quote from: Luke51411 on March 16, 2014, 08:25:10 PM
Love the knob on that build.  Classic.
italianguy63
smurfedelic smurfberry
Though not technically on topic, i thought this might be relevant to your interests. I got all the parts for the Phantom Octave to fit in this enclousre, but some crap happened on the way. But it sure looked nice!
Hi! My name is Petter and I'm from Sweden. This is my blog: http://ptelectronics.tumblr.com
artemijs
Multi Face Fuzz - there are two switches - one switch is for capacitors 0.1uF and 0.047uF becouse I dont have Tone potentiometer, and 3pdt switch for switching BC550 and 2N5088 transistors, transistor 2222A I use as a first transistor.
pickdropper
An EP Booster with an internal 18V charge pump (Switch on top is to go between 9V and 18V)
