Show me your 1590A enclosures/pedals...
Started by andrew_k, January 29, 2008, 09:42:28 PM
pickdropper
Those knobs are from Small Bear.  I buy them by the bucket.
Cozybuilder
#2121
Nate- maybe SB?
http://smallbear-electronics.mybigcommerce.com/aluminum-black-index/
Edit- I replied too quick, hadn't seen PD's post. When am I going to learn to look at the page number in the thread?
Perrow
Quote from: Cozybuilder on October 13, 2015, 10:49:23 AM
That dog's bitten me too.
Quote from: Cozybuilder on October 12, 2015, 12:50:39 PM
Wow, I think you just won the tidiest 1590A build award  8)
Placing two large pcbs hiding the wiring helps  ;D
pickdropper
Quote from: Perrow on October 13, 2015, 06:07:05 PM
Well, there is some truth to that, really.   I do put the wires under the board and I don't make them as tight as possible (tight is bad).  This one is fairly tidy under the board.  I've done a couple of more complicated 1590a builds that had a lot more wire underneath.  One in particular had so much hardware underneath that I had to make certain wires longer and the parts needed to be loaded in a specific order.  I won't be building that one again.
amz-fx
Just starting to work on putting a mosfet booster module into a 1590A:
Best regards, Jack
Lemontheo
#2125
Hi,
my first post !
Here is a Fet preamp booster, with a darlington buffer.
And a 40watts amp (based on the TPA3106D1), with AOP buffer.
Théophile
hello, lemontheo, and welcome. those are nice looking things, especially the rooster, but I have two questions for you: where do you get colour matching dc sockets, and can you, please, resize your images for your second post, so we can see all your builds, in all their glory?
Lemontheo
Thanks !
I've resized my photos.
For the yellow DC socket, it's from Musikding.de
bloxstompboxes
Tayda has red and white ones. I seem to remember them having others as well, but I don't see any on there other than these I mentioned and the usual black ones.
playsforfun
amz-fx
Here is the finished pedal for which I posted a couple of pix earlier. There are more pix in my blog at:
http://www.muzique.com/news/mosfet-booster-module-in-1590a/
regards, Jack
mfunky
Quote from: amz-fx on October 24, 2015, 11:03:25 AM
regards, Jack
I built an amz mini booster in a 1590a, with battery and LED. Thank you for that great circuit, use  it all the time [emoji6]
free electron
A quickie project for my mini looping pedalboard and an excuse to finally use that MSP430 Launchpad i got few years ago:
a stepped expression pedal emulator, basically an MSP430F2012 controlling a digital pot.
The output setting can be stepped in 1(on/off), 2,4,8 or 16 equal steps (configurable), LED bar shows the value, the last used setting is restored on next power up, short clicks step the value, holding down the footswitches jumps the setting to min or max.
I didn't have enough space left for a full scale expression pedal, one 1590A was all i could squeeze in.  For a simple task as master volume controller having 8-16 available steps does the job pretty well.
amz-fx
Quote from: mfunky on October 24, 2015, 01:28:54 PM
Thanks for your kind comments. I'm glad you are enjoying the booster pedal.
Best regards, Jack
amz-fx
Quote from: free electron on October 24, 2015, 01:58:45 PM
Looks great! Well done.
regards, Jack
Marcos - Munky
#2137
Here's my new ones. The first is a Soulsonic's Folk Driver. This is a very nice low gain overdrive, which sounds very good alone and amazing when boosting another drive. And since it's a drive, I used a image of a "drive" as the artwork  :icon_lol:. This was my first attempt with this kind of etching, and I decided not to paint it because the etch isn't deep enough.
The 2nd is a Mictester's Really Cheap Compressor. Like the Folk Driver, the etch isn't deep enough to paint. It's been a long time since I used a compressor, and like Mictester said about this one, it will be on all the time.
Ben Lyman
Quote from: Marcos - Munky on October 26, 2015, 03:29:30 PM
Wow, those etchings look great, good job! I wanna learn how to do that instead of trying to paint.
Would you recommend either of these circuits for a beginner?
I have made FF's, TB MKII's, boosters, and RM's but I want to build a TS(ish) type of light O.D. and a comp.
        -S. Vai
Marcos - Munky
Both circuits are pretty simple. But I'm not sure if the Folk Driver is TS(ish). Actually it's been a long time since I played something TS(ish) :icon_lol:.
For the etching, see this video: https://www.youtube.com/watch?v=2cg4UoS6ecY
