Show me your 1590A enclosures/pedals...
Started by andrew_k, January 29, 2008, 09:42:28 PM
deaconque
Quote from: kurtlives on July 09, 2009, 11:25:26 PM
^chickheads?
Where did you get those mini ones Dan?
If you're looking for mini chickenheads you might want to pick up some used rocktron pedals.  most of them have them and they also come in cool enclosures.
This used to be a Rocktron Silver Dragon
juse
Quote from: elshiftos on July 17, 2009, 06:48:47 PM
Ta for the tip. Just today I was soldering a dr boogie and thought I really should start cleaning the flux off my boards!
Any suggestions for removing the stuff after it's been on the board a while?
Cheers
It depends on the type of flux being used, but you could try warm soapy water on a toothbrush, a clean water or rubbing alcohol brushing, then dry off with an air compressor nozzle if available. This is assuming it's not assembled in a box, though...  :icon_wink:
JKowalski
Hey, I was just gathering up a part order at digikey today and I noticed these:
http://search.digikey.com/scripts/DkSearch/dksus.dll?Detail&name=1775390-2-ND
Thought someone might be interested.
nocentelli
Valoosj
Quote from: frequencycentral
You squeezed it into a 1590A - you insane fool!  :icon_mrgreen:
Quote from: Scruffie
Well this... this is just silly... this can't fit in a 1590B... can it? And you're not even using SMD you mad man!
kurtlives
My DIY site:
www.pdfelectronics.com
solderman
The only bad sounding stomp box is an unbuilt stomp box. ;-)
//Take Care and build with passion
www.soldersound.com
xSolderman@soldersound.com (exlude x to mail)
kurtlives
My DIY site:
Meathead virtually is a FF isn't it? If we say COKF is a FF. Same family at least.
guitarjoem
Here are three of mine:
A Bazz Fuss, a buffer, and a control for my rotary speaker cabinet.
azrael
gena_p1
some bootique 1590A (thanx to Termozzzz)
deaconque
Quote from: gena_p1 on August 16, 2009, 03:45:53 PM
anyone know where to get some knobs like that?
earthtonesaudio
Br4d13y
this is one of those times where i feel dilly because ive never thout to lay the battery that way :icon_rolleyes:
freedom is the freedom to say 2+2=4
andrew_k
1) That's a photoshop mockup
2) There's only one 1/4" socket.
3) The battery won't fit once there are two 1/4" jacks in there
4) Both the graphic and circuit design are disturbingly similar to this - http://www.clinchfx.com/ep-pre
Gila_Crisis
spaceace76
it definitely looks like photoshop, but Peter didn't invent the EP-Pre, he cloned it when he saw that there was a market for it, and a reason for it's renowned tonal response. I've spoken with him at length about cloning it myself, I doubt he would care if another company made their version of it. Unless they used his PCB layout without permission, that is. But they don't show the board, so no need to jump to conclusions.
I'd like to know where to get transparent knobs as well!
Thomeeque
Hi! Is there a schemo for EP-PRE somewhere? I'd tried to google it, but did not succeeded so far.. Thanks, T.
Do you have a technical question? Please don't send private messages, use the FORUM!
earthtonesaudio
Quote from: deaconque on August 16, 2009, 08:02:04 PM
I second that... That looks like a Davies #1510, but I sure can't find one in clear.
