Show me your 1590A enclosures/pedals...
Started by andrew_k, January 29, 2008, 09:42:28 PM
Valoosj
Tycobrahe octavia. The LEDs were a pain in the ass to install.
Quote from: frequencycentral
You squeezed it into a 1590A - you insane fool!  :icon_mrgreen:
Quote from: Scruffie
Well this... this is just silly... this can't fit in a 1590B... can it? And you're not even using SMD you mad man!
azrael
Whoa, is the Octavia with the Transformer in there? Tight squeeze! What layout did you use? :D
Valoosj
It is. As usual I made my own layout. The little slider switch next to the footswitch is to disconnect one of the diodes.
azrael
Woe, I'm going to have to try my hand at a 1590A layout, then. That looks super cool. :D
gena_p1
Just finished
20 month of work. I was not sured about result until last month... I used surface mounted resistors size 1206. Cause it possible to put 'em under caps and ICs.
Hides-His-Eyes
Taylor
Quote from: Hides-His-Eyes on December 19, 2010, 07:50:03 PM
Valoozi are you IN Yndi Halda?!
I think it's the thing where people write the name of the song they were listening to when they finished the pedal.
Valoosj
Exactly. I wish I were in Yndi Halda though, awesome band. Or maybe Pg. Lost  :icon_smile:
solderman
Quote from: gena_p1 on December 19, 2010, 05:22:32 PM
Just finished
OMG  :o  :o  :o  :o  :o
Amazing machine. You made the Small Clone fit in to a 1590A
Hat's off and respect, BIG TIME.
Of cause some SMD is cheating but most of the components seam to be normal ones so I would say it counts.
Again....Grate work. This is some serious piece of "no shit get it to fit"
;D
The only bad sounding stomp box is an unbuilt stomp box. ;-)
//Take Care and build with passion
www.soldersound.com
xSolderman@soldersound.com (exlude x to mail)
Zapp Brannigan
Gena p1, Ковер и котэ труъ! Good job, dude!
gena_p1
Quote from: solderman on December 22, 2010, 09:30:28 AM
OMG  :o  :o  :o  :o  :o
Again....Grate work. This is some serious piece of "no sh*t get it to fit"
;D
Thanks! SMD 1206 takes as much space , as vertical mounted resistor, but they could be soldered under ICs or Caps. I think, in low space it was no another choice.
skrunk
wow that really is a small clone of a Small Clone!
great job.
miska
gena_p1
azrael
Awesome!
How do you manage to do double sided PCBs?
solderman
www.soldersound.com
arma61
"it's a matter of objectives. If you don't know where you want to go, any direction is about as good as any other." R.G. Keen
nocentelli
Hey, it's a "small clone" of a small clone... clever. ;D
Yorick
gena_p1
Quote from: azrael on January 23, 2011, 12:20:54 AM
Awesome!
I did single sided PCB for "laser iron" - toner transfer. But my friends, engineers did urgent order of PCBs for their needs, and had some free space, for couple of small clones. Thats why holes are metallized and PCB is double sided :)
Only 3 jumpers and one zero Ohm resistor. No 2nd layer really used.
This PCB contains mistakes - R80/22K (used wired on photo), R62/12K, and LFO time cap - connected to pins 2,3, but must be connected to 1,2 of lm358. Not very perfect, but, it's working.
Red - power, brown - ground, coffee-cream - bias
