Show me your 1590A enclosures/pedals...
Started by andrew_k, January 29, 2008, 09:42:28 PM
In the Toronto area, Sayal and A-1 Electronics have 1590A's.  They are a little bit cheaper at A-1 but there is more selection at Sayal.
PereatMundus
#621
@tasos
Just walk into any decent electronics supplyer anywhere in the developed world and they should have it or can order it shipping free ;)
Its a global standard enclosure.
and now:
FUN!
Hey:
Just thought I'd share a wild sketch:
this is -physically- possible to set up AND sort of.... use in a SMALL gigbag style Pedalboard.
Specifically the:
Road Runner Pedalboard All-In-1 Gig Bag (the one I use, and sketched for)
Size: : 2-1/2"H x 12"W x 21-3/4"D
Just a quick mockup, I did in 5minutes, but its more or less exactly to-scale, and spaces work with snug enough cables, or jack-jack plugs.
so you would fit all this for instance:
( Possible in 1590A setup proved in this thread or otherwhere on  interwebs: )
a Wah-Pedal
to the right ;)
Its possible to "for instance fit:
-18- 1590A's (vertical)
OCD(custom layout)
Timmy(modded)
a Fuzz
ValveCaster
RAT(modded/customlayout)
Octave
Machine(modded)
Compressor
3switchable boosters in one 1590A
Mxr NoiceGate(modded/custom)
BBE Sonic(modded/custom)
Tuner(modded)
Powerstation(custom power-supply to drive pedals)
Malekko Reverb
Small Clone(custom)
Mxr 6bandEQ(modded)
Tuner(Modded)
CopyCatDelay
*not the best choice; but just to make the point ;)
in the 2 small boxes over the Wah,
1Booster, and 1 sattelite-Noicegate momentaryswitchOFF(mod)
in the horizontal 1590A.
Routing
in the horizontal bottom.left bar:
dedicated channel Router/switcher
Insane.. fun ;)
Guitars: Westone Prestige 150 - Aria Pro II CS-400BnG
Amps: 5150 - SloClone
Fx: 20+ DIY (100+)
Play: Kraut/Death/Industrial/Noise
Pereat Mundus Et Furia Tempo-Leena Krohn/Schopenhauer
neurino
Hullo everybody, it's been a while since my last effect in a small box but I found the time to do this at last:
it's a Marshall Blues Breaker clone as in notepad schematic, but with a RC 4559 instead a TL072 (please notice I made a mistake in the layout so I had to flip pins of the IC and put it in the socket upside down lol ::) :P )
The "decal" is made with a reverse toner mask then darkening the uncovered aluminum with hydrogen peroxide (in other words an etch without etching...), removing toner and then adding clear coat.
and here the gutshots... a bit crowded in there:  :icon_mrgreen: under the stripboard three 9mm alpha pots
Hides-His-Eyes
Quote from: tasos on February 04, 2011, 04:17:40 PM
hmmmm...i had a look around but most sites have crazy shipping!only small bear is pretty reasonable....i am not going to pay 6 for the enclosure and 10 for the shipping! ;D
The first rule of electronics is: you never buy one of anything.
solderman
#624
Hi
Some times things take a little longer than you expected. This project was meant for the 666 competition. But a slow delivery of the small pot's crashed that plan. But better late then never. So here folks, meet The "Boogie Man" Its, as you might suspect a Dr. Boogie only in a slight smaller costume than you usually find him.
The paper decals is to be changed for water slides soon.
Soundsample:
http://solderman.fatabur.se/DR_Bogie/DB.mp3
The only bad sounding stomp box is an unbuilt stomp box. ;-)
//Take Care and build with passion
www.soldersound.com
xSolderman@soldersound.com (exlude x to mail)
Renegadrian
ultran8
that is unbelivable . great job man whats is sound like . and whered u get your pots from i been lookn for those. your awesome man thise is my feeble attempt so far with this box. it was a impedence changer for mics so i added the g and made it a fuzzface . not near your caliber but fun!
Uploaded with ImageShack.us
neurino
@solderman: hats off, really stunning :o
Don't want to bother but... no led?  :icon_mrgreen: :icon_mrgreen: :icon_mrgreen:
Joecool85
So, my big question with these builds: how well does the stomp button work?  I'd think with it being such a small enclosure and most of these have the button ALL the way on one end it would flip up when you step on it.  Am I wrong thinking that?
I might have to get a circuit into one of these bad boys.
Life is what you make it.
https://www.ssguitar.com
Valoosj
It really doesn't flip up, and if it does, use velcro.  :icon_biggrin:
Quote from: frequencycentral
You squeezed it into a 1590A - you insane fool!  :icon_mrgreen:
Quote from: Scruffie
Well this... this is just silly... this can't fit in a 1590B... can it? And you're not even using SMD you mad man!
Joecool85
Quote from: Valoosj on February 18, 2011, 02:14:39 PM
I suppose you could rework the design to have the button in the middle...that should work I would think:
Top of pedal
Out
  STOMP
             IN
Bottom of pedal
**edit**
I'm thinking of using it for a basic stutter pedal with a three part layout: two jacks and a switch that grounds out the signal when stomped.
tasos
#631
hey guys....what is the dimensions of this box please?
92x37x30mm...
i found the dimensions by chance just right after i posted! :icon_razz:
i only have access in these dimension boxes 35x75x30 or 35x95x30....i will probably go for the first!it is actually smaller than the hammond! :icon_razz:
solderman
Quote from: neurino on February 15, 2011, 08:37:47 AM
There is one under one of the eye of the ghost.  ;D
www.soldersound.com
Valoosj
Quote from: neurino on February 08, 2011, 04:39:30 PM
Where did you get those power jacks?
Valoosj
blooze_man
Wow. Mind sharing how you did the glowing ram's head?
Big Muff, Trotsky Drive, Little Angel, Valvecaster, Whisker Biscuit, Smash Drive, Green Ringer, Fuzz Face, Rangemaster, LPB1, Bazz Fuss/Buzz Box, Radioshack Fuzz, Blue Box, Fuzzrite, Tonepad Wah, EH Pulsar, NPN Tonebender, Torn's Peaker...
Valoosj
tubelectron
Hi All,
This collection of super-compact Fx's is again and again simply delirious & delicious...
Now this is my time to contribute, at last, with my 2000 Pound Bee - a Mosrite-FuzzRite-Ventures fuzz pedal.
Note that it is a full-feature unit, incorporating battery, battery holder, ext. PSU jack with battery cut, input jack with battery cut, blue 3mm led, so it can be used as a standalone item.
A+!
I apologize for my approximative english writing and understanding !
http://guilhemamplification.jimdofree.com/
elshiftos
