Show me your 1590A enclosures/pedals...
Started by andrew_k, January 29, 2008, 09:42:28 PM
Barcode80
Quote from: PereatMundus on May 31, 2011, 11:36:56 AM
Green Ringer
Meathead
fuzzzzsszzrrrr
Just a tip for you, those locking washers should go on the inside, not the outside. You are going to damage your paint.
tasos
i do the same and i have no problem...basicly if screwing the switch without them then the paint is scratched!
and it also looks so hardcore! ;D lol
^ thats why a lot of people use those horrible white plastic washers i guess!...nasty looking though!.. :)
PereatMundus
#763
Quote from: Barcode80
thanks.
Actually most of my 1590A boxes dont get used much at this point.
I still need to have decals made and a finishing clear gloss paint.
I really hate the stock plastick washers that come with the switches.
Need to buy new large chromed ones.
then the locking washers will go inside I promise :)
I have 4more 1590A done now  :icon_biggrin:  But hedding out on vaycation in a few days.  pics when decals are done.
Guitars: Westone Prestige 150 - Aria Pro II CS-400BnG
Amps: 5150 - SloClone
Fx: 20+ DIY (100+)
Play: Kraut/Death/Industrial/Noise
Pereat Mundus Et Furia Tempo-Leena Krohn/Schopenhauer
PereatMundus
#764
Quote from: azrael on May 31, 2011, 10:00:51 PM
Do you 4 knob 1590Aers have drilling templates for your enclosures? That seems so hard!
4knob and even 6knob 1590A is easy as long as using 12mm or 9mm Alpha pots :)
no drilling templete needed.
Fx: 20+ DIY (100+)
PereatMundus
Fx: 20+ DIY (100+)
oh yeah i remember that now....crazy!.. :icon_cool:
PereatMundus
Quote from: deadastronaut on June 05, 2011, 11:24:00 AM
Forgot to say thank you for the  "  :icon_eek: "
Fx: 20+ DIY (100+)
Quote from: PereatMundus on June 05, 2011, 11:30:49 AM
no problem!...great builds man...heres 2 more!.. :icon_eek: :icon_eek: :icon_mrgreen:
EATyourGuitar
my first 1590a. also my first etching that didn't fail. I am quite happy that I'm finally getting some winning
WWW.EATYOURGUITAR.COM <---- MY DIY STUFF
allesz
Hallo everybody.
I post here my new effect just to show that my small addiction is still quite bad: this time it is just a super simple germanium booster (input cap, output cap (both 1uF), a resistor to ground, a pot, that's it). It is so simple that the circuit stays on a 1cm x 1cm perfboard, but it sounds good and it is a way to use bad and too leaky germanium transistors (the trannie is biased only by leakage); it can go from full frequency boost to just unity gain "buffer", anyway usefull and good sounding.
Of course it works only with the 9v battery, and no led, so i called it aleakysnob.
nocentelli
Mr. Slave
My mini pedalboard
...just one intruder
rockhorst
THAT is extremely nice to look at! Now plug 'em in!
Nucleon FX - PCBs at the core of tone
tasos
so is there a layout of the little angel chorus for the 1590a? ???
Barcode80
Quote from: tasos on June 13, 2011, 03:54:06 PM
Yes, it is in the Little Angel thread.
