Show me your 1590A enclosures/pedals...
Started by andrew_k, January 29, 2008, 09:42:28 PM
Güero
Curing the infection one bullet at a time.
ugly_guitar_guy
Triple trem attack! A few tremolos that I finished tonight for some friends. :) (FYI, the color is deceiving. The right side "speed" knob flashes green with the rate, the left "mix" knob is the status indicator)
Check out my metal band here: www.facebook.com/hollowshell
or
my personal effects building page here: www.facebook.com/brotronics
Güero
#943
azrael
wow, your drilling precision is surgical! how do you do it?
Güero
Quote from: azrael on January 14, 2012, 12:40:21 AM
Thks!
Some patience and
azrael
Dang, I need some calipers.
I tried your PCB mask trick, looks so cool! the red ones are preparing to go into a 1590A. :D
Güero
Quote from: azrael on January 14, 2012, 12:33:17 PM
Oh..nice!
The blue one looks great!  ;)
I never had luck with blue color  >:(
^ooohhhhh they look cool... i missed how that is done?. ::)
ugly_guitar_guy
Quote from: deadastronaut on January 14, 2012, 05:51:28 PM
agreed, that's pretty slick.  :icon_cool:
or
azrael
really?..and you solder through it?....hmmmmm.... :-\
artifus
you could mask off the pads with a blob of blue tack or whatever before spraying.
azrael
Quote from: deadastronaut on January 14, 2012, 10:21:19 PM
i haven't had problems with it yet, and neither has Guero, as you can see by his awesome builds. :D
I'm considering tinning them beforehand though. Should make it super easy to go through the paint for a solder joint.
You can solder right through the lacquer with no problems. Tinning would just be an unnecessary extra step as the lacquer's going to prevent the copper from oxidizing and hampering soldering, (which is why you tin in the first place is it not?)
Take care,
dave
tasos
Quote from: davent on January 14, 2012, 11:18:15 PM
Take care,
dave
So laquer actually does good to your soldering? ???
^ i would have thought it would 'gunk' up your carefully preserved iron tip...hmmmm...
azrael
Take care,
dave
tinning also makes heat transfer more efficient, no? That's why it's easier to solder something that is tinned?
I have not had problems with the spray paint and my Hakko tip. I clean mine quite a bit during projects, though, even before this spray paint mask business. :)
The thermal conductivety of copper (think high end cooking pots & pans) is many, many times greater then that of either lead or tin so i'll stick with my assumption that tinning mainly serves as a preventative to copper oxidization.
http://www.engineeringtoolbox.com/thermal-conductivity-d_429.html
Like azrael, i frequently clean my iron tip and can't say i've ever noticed any gumming up as a result of the lacquer, the lacquer appears to pretty much vaporize on contact with the iron, something else to breath in.
As to lacquer helping the soldering, again it's just another measure to prevent oxidization (and looks cool) so yes it should be helping long as it's applied soon after the copper is cleaned, before the copper has much chance to oxidize. (Again my assumptions).
dave
azrael
Say what you will, but pretinned wire solders a lot easier and faster than non tinned wire.  :icon_biggrin:
