Show me your 1590A enclosures/pedals...
Started by andrew_k, January 29, 2008, 09:42:28 PM
Govmnt_Lacky
rousejeremy
Nice. I still can't find a 4580 chip for mine. I have a TLO72 in there at the moment, still sounds great.
www.jeremyrouse.weebly.com
guitarmageddon
Thanks G-man!
@Jeremy, I'm not convinced it will make a huge sonic difference, but at only 38c each they're cheep as...erm... chips. ;D
http://www.ebay.com/itm/281038813679
amz-fx
A project that I just completed was a mini-amp in a 1590A box for practicing. This tiny powerhouse can provide up to 5w, but 1w is closer to the practical power for a mostly clean output. I plan on plugging this into a 4×12 cabinet to see what it can do.
Best regards, Jack
Maik
Can´t believe how small it is! Amazing! You guys rock!
midwayfair
Last few minis:
Tonebender MKII ... sorta.
"... Peanuts to Space" a 1590A Belton reverb. The PCB is actually a smaller footprint than the brick:
Madbean Zero Point Micro with the modulation rate knob external.
amz-fx
Beautiful, pickdropper! Great job!
Best regards, Jack
noobamp
man.....everytime I see a pickdropper-made 1590A box I want to hang up my soldering iron....
nothing like the smell of hot Bovie in the morning....
pickdropper
Quote from: noobamp on September 07, 2013, 01:18:53 PM
Don't do that!  Solder more!
alanp
Metal knobs, extremely clean laser etching, very classy, elegant boardwork inside... I knew it was PD's work before I even looked at the left column :)
pickdropper
Sir Robin!  (Nurse Quacky layout from ChuchBuick on BYOC).
The first pic is terrible and will be retaken at some point.  The whites bloomed quite a bit on the photo.  It's much sharper in person.
^ me too, pickdroppers soldering iron must be a needle.. :icon_eek:
pickdropper
Thanks guys.
Btw, it isn't a Nurse Quacky, it's a Mutron III /Meadball hybrid that Harold at Sabrotone came up with.  I got it in my head early that this was derived from the Nurse Quacky circuit, but that isn't correct.
I actually use different soldering iron tips depending on the application.  I have 5 different tips I use, 3 of which are used on regular basis.  For SMT stuff, a finer tip does help.
lars-musik
There are so many astonishing builds in this threat that I just had to shrink something myself.
So, this is my first attempt on the small ones - the overdrive section of the box of rock. One of my first layouts so there certainly is room for improvements.
However, I'm fairly proud of it.
OK, so I didn't give up just yet...   ::)
Joe Davisson's "EZ-250" overdrive, and a Bazz Fuss on a Poodle's board.
pickdropper
Quote from: lars-musik on September 15, 2013, 05:35:37 AM
You have good reason to be proud of it.  Looks great.  Dig that etch.
