fulltone ocd repair
Started by Don, January 30, 2008, 11:10:48 AM
Don
any help on fixing a ver2 ocd that conked out on me ? it has been modded to a ver3 (worked fine) ...1 wire got loose and I resoldered it and later on , only the led works, no sound, bypass works ...... the loose wire that I resoldered is on the rightmost side of the pcboard (hooked up to the dcjack) ....this version is gooped so i might be out of luck  :icon_frown: ......any advice would be greatly appreciated
For what they charge, Full-Tone should be able to talk you through that repair.  Call 'em up.
Don
unfortunately that is out of the question....like i said, this is a gooped ver2 w/c I upgraded to ver3.... had a hard time to convince them to send me the upgrade parts (when they were offering them a while back) since this is the gooped version ......the v3 upgraded pedal worked really well for quite some time.....was just replacing the battery when i noticed that the wire from pc board to dc jack was loose so i soldered it back (pc board side)...... was thinking there might be a diode in there that i fried? thanks ...
