Stereo RG´s F*nder - like vibrotremolo/Vibratone/brownface vibrato?
Started by Morocotopo, February 05, 2008, 11:07:06 AM
Morocotopo
Just a thought that came to me.
Wouldn´t it be nice to make this thing stereo, like this: two outputs, and the hi/lo pass filters or whatever they are alternating between the outputs?
like this (highly technical explanation ahead):
LEFT      RIGHT
U           A
U           A
A           U
A           U
U           A
etc. (Don´t laugh, I can see you!)
Don´t look at me! I can hardly draw an IC buffer without messing up... :P
Just a thought.
Morocotopo
Morocotopo
Processaurus
I tried that this in this pedal.  I'll make a sample of it some time.  It's neat, I need to try it with two amps, in headphones it makes me kinda nauseous :icon_mrgreen:.
Morocotopo
That´s some rat´s nest of wire and PCB´s you have in there!  :D
You used R.G.´s schem as a starting point ?
A sample would be nice, if and when you can.
So, I´m not THAT crazy in my thoughts. Hmmm.
Morocotopo
Morocotopo
Processaurus
It was kind of an add on to an existing version of the transmogrifox version of the EA (more depth).  It was a panner already, the ersatz vibrato was added later, taking advantage of the existing panning outputs.  It uses the same filters as are in RG's thing as well as the original fender schematic.  each panning channel went to its own HP and LP filter, and then the HP and LP filters of the opposite panning channel got mixed.
like
Panning channel A ----> HPF A and LPF B
Panning channel B ----> HPF B and LPF A
HPF A and LPF A get mixed to one output,
HPF B and LPF B get mixed to the other output.
I actually wouldn't recommend doing it like I did, it was a lot of parts.  Just one of those projects where whenever there was an idea of something to add on, it got added.
