Adding clipping diodes to booster circuit -- functional difference between . . .
Started by bipedal, February 05, 2008, 11:17:34 AM
bipedal
Apologies in advance for the rudimentary text-based graphic, and what's probably a rather rudimentary question too...
Here's two basic arrangements for using a pair of diodes for clipping near the end of a booster circuit.  Functionally, can these be considered the same?
I'm curious if there's any difference, because the 2nd signal path arrangement below seems to lend itself better to a simple single throw switch to make/break the connection to the diodes (for example, to switch between 'clean boost' and 'diode clipping' modes...)
- Jay
In ------------------- Out
         D1    D2
         Ground
         D1    D2
          Ground
"I have gotten a lot of results. I know several thousand things that won't work." -T. Edison
The Happy Household; The Young Flyers; Derailleur
dano12
Those are functionally identical. The latter makes for easier switching as you point out.
bipedal
Great.  That's what I suspected, but thanks for confirming -- much appreciated.
My soldering iron awaits...
Cheers,
- Jay
