easily removing ICs from sockets?
Started by gutsofgold, February 06, 2008, 11:57:50 PM
gutsofgold
It seems those ICs stay in sockets all too well. I usually find myself trying to pry them out with tweezers and tonight I got the best of a JRC4558 and chipped a corner off it.  :icon_sad: (It still works!)
What do you use to quickly and easily remove those stubborn chips?
zachomega
sshrugg
I just slide a toothpick under one side, lift a little, then go to the other.  Continue until it's out.  A toothpick will break before your IC does : )
Built: Fuzz Face, Big Muff Pi (Stock), Distortion + (Germanium and Silicon versions)
birt
flat tip screwdriver.
push it unde one side and the further you push the thicker the tip gets and the IC comes out of the socket
http://www.last.fm/user/birt/
