Which is a better sub for 2N5457: BF244 or BF245?
Started by gigimarga, February 13, 2008, 12:39:52 AM
gigimarga
Here, in Romania, it's very hard to find 2N5457, but there are a lot of BF244/BF245.
Which of them is a better sub for 2N5457?
J201 can be used instead of 2N5457 (especially in ROG's Thor and Omega)?
Thx a lot!
http://www.datasheetcatalog.com/datasheets_pdf/B/F/2/4/BF245.shtml
  Says it's an N channel, good for audio and radio frequencies, sounds pretty good for the intended purpose.
  Link to download on 245:
  http://www.datasheetarchive.com/preview/851030.html
  Looks like about the same thing, the second transistor in Omega is mosfet.
George Giblet
BF244 is pretty much the same as the BF245.  Both come in A, B and C suffixes.
The best sub for the 2N5457 is the BF244A/BF245A.   The philips cross reference seems to say the same thing:
http://www.nxp.com/acrobat_download/other/discretes/Philips_RF_Manual_2nd_edition.pdf
A lot of amplifier circuits will work with widely varying characteristics.  J201 vs 2N5457 shows just how loose a match you can get away with.
gigimarga
Thx a lot...only problem remains that i have a lot of BF245C :D...but i will look after BF245A!!
mac
I'd say BF244/5 A.
I never had bias problems using BF245 A, I mean distortion, compressors, phasers, tremolos, etc.
I use BF245 C to replace MPF102, and 2SK117 instead of J201.
mac
Plexi
#6
Quote from: mac on February 13, 2008, 10:30:41 AM
I'd say BF244/5 A.
mac
I agree with that
No need to re-biasing the JFet
Which values are the most important to compare JFets?
I'm readint the datasheets
To you, buffered bypass sucks tone.
To me, it sucks my balls.
mac
QuoteWhich values are the most important to compare JFets?
Yfs, forward transfer admittance
Vgs(off)
mac
Plexi
maiko
MPF102   Tried this on projects
just research pinouts again
distortionhead
I'd say BF244/5 A.
mac
voltage and bias settings? pinouts are the same? got some bf245c thinking of doing a distortion may be a bsiab ii thoughts on that?
mac
Quotevoltage and bias settings? pinouts are the same? got some bf245c thinking of doing a distortion may be a bsiab ii thoughts on that?
I never breadboarded a BSIAB. But 245C can work fine.
mac
Plexi
I would use BF245 instead of the 2n5457, as Mac says.
You will not have problems with bias.
distortionhead
will try and get back.. first would like to try a simple fetzer valve circuit. :icon_lol:
Plexi
Fetzer valve is great and simple to start.
It's good to learn and try some adds
