BC556B transistors
Started by DryRoasted, February 13, 2008, 04:20:03 PM
DryRoasted
Evening all,
Can some one give me a substitute for a BC556B tranny please?  I need one for (of all things) an interface for a dive computer http://vyper.bunny.hu/eng/Roli/parts/cvmif.pdf.  Although like most three legged objects I get my hands on, I'll plug it into a rangemaster clone and see how it sounds :)
I've not had much luck with google, and although with a stompbox I'd not be too fussy about tranny selection, in this case I don't want to deviate.
thanks,
Jim
Sticking a tube into a tube screamer to get good sound is about like rubbing yourself all over the weight stacks at the gym to get stronger - R.G.
rocket
try to google without the b at the end
it's a medium gain pnp like 2n3806
> 2n3806
Typo? 2n3906
The BC556 higher voltage than many small transistors (VCBO=80V, VCEO 65V).  The 2n3906 is more normal (VCBO=40V, VCEO=40V).  The BC556 is useful in power amplifiers which have higher voltage rails.
Dragonfly
According to the NTE cross reference, a NTE159 will work.
I have had "mixed results" with NTE cross references.
jpm83
Have you checked BC558B and BC559B?
Janne
Johan
its just a general purpous PNP, you can use pretty much anything in there..the Suuntoo watches operate on a single 3volt lithiumbattery, so even the voltagerating is not important.. ...I built one of thoose too for my "Stinger".  ;D
johan
DON'T PANIC
DryRoasted
Quote from: Johan on February 14, 2008, 11:00:56 AM
johan
Thanks for the replies guys.
Johan,  Did you use the 556B's as specified, or substitutes?
Minion
I would try a BC560B ,It shares the same Datasheet as the BC556b and has allmost the exact same specs accept for Voltage ....
Go to bed with itchy Bum , wake up with stinky finger !!
