Your Build order
Started by criss, February 23, 2008, 09:51:11 AM
criss
G Day all
What order do you do your builds in ?
After  you populate your pcb what order do you work from there .
Is it best to drill the enclosure and have all your wiring on the pcb done then do the pots switch etc while there in the enclosure .
Any and all tips would be a big help
Thanx
cpnyc23
I tend to it in this order:
1. Compile all the parts
2. Sketch a layout for the enclosure
3. Drill the enclosure
4. Sand
5. Prime
6. Paint
7. Decal
Next Day
8. Clear Coat (3 or 4 coats depending on the enclosure - usually sanding in between)
9. Build the circuit
2-4 Days later
10. Confirm that clear coat has cured
11. Populate the enclosure
Sometimes I do things in a slightly different order (I have a number of circuits that are built, just waiting for the enclosure).
The main thing for me is to make sure that I give the enclosure enough time to cure.
Stupid patience... always getting in my way.  :icon_rolleyes:
-chris
"I've traveled the world and never seen a statue of a critic."    -  Leonard Bernstein
BarnabyHooge
Dragonfly posted this in the Beginner Project section.
http://www.diystompboxes.com/smfforum/index.php?topic=64140.0
It's a great guide to keep around.
