1st time try @ Breadboarding
Started by J.D., February 24, 2008, 05:51:02 PM
J.D.
    This is my 1st breadboard attempt ever and it sounds pretty good to me. I used a TL071 for the IC, works fine and I really feel like I learned a little bit about
how this stuff is done (probably just enough to be completely wrong at most of it).
    I would like to try to commit this to a PCB and box it up(maybe use the diode compression project instead of an IC). I just attempted my 1st PCB layout using the DIY Layout Creator but I'm not at all confident it's right. I'm sure I wasted some board space but that's about all I'm sure of.
    What's the easiest way to do a layout---starting with the ground trace and working in or in this case starting with the IC and working out? Or is it better to start with the power section? I don't have a clue. Maybe all these question belong in a different thread but this is the beginners section so I thought I would try here.
J.D.
gaussmarkov
hi J.D.,  welcome to the forum! :icon_cool:
there are probably as many ways to approach this as there are people.  so take my suggestions as just a few among lots of other good ones.  perhaps others will chime in with their favourites.
to start, i like to spread out the parts more or less like the schematic.  i think i picked this up from aron's beginner project.
then i concentrate on putting in the traces for the signal path first.  i don't worry much about ground or power supply stuff until after the signal path is done.  try rotating the IC around to see what works best.  i also pay attention to pots at this stage, because i want the layout to fit where the pots are going to go, usually along the top edge.
then i keep start the +9V and the GND traces side-by-side at the bottom.  i run the ground trace more or less all the way around the outside and the +9v inside of that.  in this circuit, VA takes the place of +9V.   i treat the virtual ground (VB in this case) traces like the +9V traces.  if i seem to need jumpers, then i would restrict them to these three (GND, VA, VB) because they are supposed to be relatively "quiet" traces---their voltage is approximately fixed.
you could also try looking at what others have done after you have wrestled with the problem a little.  i have a layout for this circuit heretonepad.com has a layout.  i'm pretty sure that generalguitargadgets.com does.  i'll bet markm's gallery has a layout because he laid out almost everything before he retired from stompbox circuits.
hope this helps, paul :icon_biggrin:
gaussmarkov
ah, we are piling up posts on top of each other. :icon_wink:
it looks like you have already made great progress!
J.D.
 Hey Paul, thanks for the advice. I checked out all 3 of the layouts you mentioned and I'm not surprised they all look much cleaner and less cluttered than mine.
I'm going to study em and clean mine up a little. Maybe try to incorporate that diode compression into it. Just wanted to learn how to do it because I figure it will help me more than just taking a PCB off the net and soldering components wherever it say to solder components.
javascript:void(0);
Smiley
gaussmarkov
Quote from: J.D. on February 24, 2008, 07:53:55 PM
Smiley
i think you are right.  i certainly learn much more that way.
i hope you didn't get the impression that i was suggesting those other layouts as substitutes for yours.  i hope you do your layouts first before you make comparisons.  and that you will stick with your own.   there's a lot of satisfaction (and learning) in rolling your own.   :icon_cool:
J.D.
Quotei hope you didn't get the impression that i was suggesting those other layouts as substitutes for yours.
   Not at all,always preferred rolling my own" back in the day".
   Now to learn how to post a smiley face.
