Germanium-radio frequecy-power BJT
Started by frank, February 25, 2008, 05:21:24 PM
frank
Okay, novice question perhaps.
What can you make with Germanium radio frequency power bjt in audio?
Is it useful for audio-only projects (stompboxes, little amps, etc.)?
What is happening when you put small-signal ge RF transistors in a stompbox for a simple fuzz ?
What happens when you saturate a ge power bjt, can you have a decent sound? (ex: output stage of small amp)?
I have bought sanyo 2sb474 by error and don't know what to do with them. :icon_neutral:
Thanks in advance.
Frank
I made my way downstairs. The stairs lead the way down onto the...street. They lead all the way up too, of course, saves me having two stairways. -Chic Murray
mac
First thing to do is to measure hfe and leakage using RG method found at http://www.geofex.com/Article_Folders/fuzzface/fffram.htm
Next step most users here would do is to test them in a Fuzz Face, Rangemaster or Tonebender, if they have the right gain and leakage.
Do not worry if they are power, switching or RF transistors. Check gain and leakage, and noise/hiss.
mac
drewl
Try it you never know ;D
I pulled a couple transistors out of an old radio which measured like PNP Germaniums.
The closest cross reference I could find had them listed as a low power FET, but I tried them in a Fuzz Face build and they sound very good.
So you might get lucky.
frank
Quote from: mac on February 26, 2008, 10:30:16 AM
mac
I took some notes before on 3 of them,
Leak : About 230 uA for the 3
Gain: About 60 for the3 of them
Noise: Will test.
Thaks again Marcello :)
