Quick Transformer Question
Started by kurtlives, February 28, 2008, 04:45:46 PM
kurtlives
Basically I have a 117V/12V transformer. I want to use it for a 12V DC pedal. Would this work to get 12V DC???
My DIY site:
www.pdfelectronics.com
Mark F
Yes you'll get 12VDC , actually you'll get more (12 x 1.414) I would use a regulator to get a solid steady 12VDC
kurtlives
How would I do that? I am new to transformers
My DIY site:
jakenold
Just follow the right side of this schematic.
Jake
brett
Hi
C2 is large (2200uF per amp), while C3 is small (100uF).
IC1 is an LM7812.
You'll need a heatsink on the LM7812 if you are going to draw more than about 100mA.  A small one is ok.
cheers
Brett Robinson
kurtlives
Ok so I just need to add a 2200mF and 100mF cap and a SCR and heatsink.
My DIY site:
kurtlives
Quote from: jakenold on February 28, 2008, 05:06:47 PM
Jake
How is it going from 18V to 12V?
My DIY site:
Mark F
QuoteOk so I just need to add a 2200mF and 100mF cap and a SCR and heatsink.
IC 1 is a 12 volt regulator not a SCR.
QuoteHow is it going from 18V to 12V?
The 12 volt regulator regulates the incoming voltage to a nice steady , clean 12 VDC.  I hope that is a bit more clear. :icon_wink:
kurtlives
My transformer has wires for
120V
0V
120V
0V
12V
0V
12V
0V
I only need the
120V
0V
12V
0V
Could I just cut off the other leads?
My DIY site:
brett
Hi
That is the safest way, but you'll only be using half of the power rating of the transformer.
If you want to, to make full use of the windings, connect the 0 and 120V primaries together in parallel (0 to 0, and 120 to 120), and the same for the secondaries (0 to 0 and 12 to 12V). Assuming it is a modern, correctly labelled transformer, you'll have no problems.  However, note that with old transformers where the direction of the windings and the labels are uncertain or unclear, connecting windings that were never meant to be connected can be hazardous to the point of fire, explosion, etc.
cheers
Brett Robinson
kurtlives
What do you mean I will only be using half of the transformers power rating? Is that an issue?
My DIY site:
brett
Hi
your transformer will have a rating in Volts x Amps (VA).  It will typically be 6 to 12 VA.  As the output will be 12V, 6VA  = 0.5 A output, and 12VA = 1 Amp output.
Transformer maths can be complicated, but here's a simplified version of reality that will keep you out of trouble.  Assume the VA rating is for all of the windings.  In other words, if there are 2 x 12V output windings in a transformer rated at 12VA, each gives 0.5A for a total of 1A.  (ie Each winding has its own inpedendent rating, and you should only draw as much current as the individual winding is rated for).  So in your example above, ignoring one of the primaries and one of the secondaries will reduce the VA rating by 50%.
cheers
Brett Robinson
kurtlives
Ok so if I cut off 12V, 0V, 120V and 0V I should still ahve the current to power a Tube Driver? 500mA
My DIY site:
kurtlives
I think this is right, could someone check it? I am mainly concerned about the 7812s pinout.
My DIY site:
brett
Hi
the pinout for the 78XX series is really simple.  If only other devices were so sensibe.
Hold it up with the metal tab at the back and the legs pointing down.  The left leg is where the unregulated voltage goes in, and the right pin is where the regulated voltage comes out.  The middle leg goes to ground.
cheers
Brett Robinson
kurtlives
Ok thanks...
It looks good then? Also would there be any sense putting in a fuse?
My DIY site:
kurtlives
My DIY site:
dxm1
Quote from: kurtlives on April 08, 2008, 05:24:33 PM
That would depend on the VA rating of the transformer.  I don't believe you posted that...
kurtlives
I have no idea what the VA is...how could I find that out?
My DIY site:
Papa_lazerous
Quote from: kurtlives on April 08, 2008, 10:33:03 PM
Ok thanks...
Yes a very good idea putting a fuse in, put it before the transformer, it may or may not save your components from damage but it could well prevent a fire if something goes wrong, although your transformer will have a thermal cut out inside too which will protect too
