I need the schematic of a very simple sinusoidal signal generator
Started by gigimarga, February 29, 2008, 07:27:11 AM
jpm83
Thanks for answering I've been planning to do a function generator of some sort, and now I have decided to make this for square/sine waves. http://sound.westhost.com/project86.htm And this for saw waves. http://www.electronics-lab.com/projects/test/010/
Janne
gez
Sorry, slip of the brain.  C is in Farads.  So 0.47uF (for example) would be entered into your calculator as .47 X 10 to the minus six.
jpm83
gez
Quote from: jpm83 on March 03, 2008, 10:49:55 AM
Did I get this right? Rt 47k, R1 100R, R2 100k, C 0,47µf =f=1131,73 Hz
http://www.play-hookey.com/analog/triangle_waveform_generator.html
Janne
Assuming that "0,47uf" = 0.47uF, then yes, the frequency would be around the 11kHz mark.  However, the amplitude of the waveform would be minuscule with only a 100R resistor for R1.
The way to set up these oscillators is to decide upon the desired amplitude first, then calculate the values of R1 and R2 to achieve this.  Rearanging the formula for amplitude you get:
R1 = (Amplitude X R2)/Vcc
It's also better to use values well above 100R for Rt, and make the cap smaller instead.  You'd be better off just adapting a schematic that is already in use.  Just make the cap smaller (the required value can be calculated by rearranging the formula for frequency).
jpm83
jpm83
gez
Quote from: jpm83 on March 03, 2008, 12:40:12 PM
Would this be worth breadboarding?
By jpm83 at 2008-03-03
Janne
Sure, but it could do with a stop resistor in series with the 10k pot.  Making the pot larger will give you a greater range, although everything will bunch up at one end if you make it too large.  There are fixes for this (see Flind's book - it's dirt cheap - for examples), but the circuit takes on a greater level of complexity.  For a higher frequency out, make the .47u cap smaller.
jpm83
Thanks for the replies. I will play around with this in next week, when my holiday ends and I get back to my flat.
Janne
gigimarga
ErikMiller
Here's one I built years ago, and still use in my shop. Jameco sells the main IC for under $5. Works great from a 9V battery.
jpm83
Janne
Well I played around with this today and 4,7nf C1 & 250k R1 gave me this at 2530,00 Hz.
Janne
jpm83
Forgot the question part. So what do you think is this usable?
Janne
JDoyle
Quote from: Paul Perry (Frostwave) on March 01, 2008, 07:39:08 PM
When I tune a fuzz, I prefer to use a triangle wave.
My thoughts exactly! AND I think it is more representative of a guitar signal BECAUSE it has the peaks. A sine is representative of a sine and a sine alone. Very very few things output a natural sine wave and in the end - a sine wave sounds boring.
Quote from: Paul Perry (Frostwave) on March 01, 2008, 07:39:08 PMAnd if you do make a triangle generator - you can run it to half a LM13700 OTA arranged as a simple amplifier & if you overdrive it by just the right amount, you get (very close to) a sine! Certainly close enough for rock and roll tweaking.
I believe the 'right amount' is 78mVp-p if I am remembering right. This is the way that almost every write up I have read makes a sine wave. Though it is the front end differential amplifier that does the overdriving, it just so happens that with a 13700 or 3080 it is already built and ready for you...
Quote from: Paul Perry (Frostwave) on March 01, 2008, 07:39:08 PMOf course, in the final analysis, a musician & a guitar is what you need. And ears.
Amen to that!!!!!!
gez
Quote from: jpm83 on March 10, 2008, 04:07:16 PM
Looks odd.  What op-amp are you using?  Try reducing the 47k resistor (RT) untill things look cleaner.  This will reduce amplitude, but by the look of things you need to do this.  Increase the cap value to compensate if necessary.
Janne, is that a fairly low samplerate software scope or USB cro? I can't see why the circuit would have given an output with shape varying from cycle to cycle.
gez
Quote from: Paul Perry (Frostwave) on March 11, 2008, 01:24:09 AM
It could be that the amp's input range is being exceeded on the Schmidt and it's causing some weirdness in the whole amp?  Or there's slight clipping in the output of the integrator - though it would latch if that were the case, so I doubt it.  The way to be certain would be to reduce the 47K to reduce amplitude and see if things clean up.  If not, then yeah, it must be the scope.
jpm83
The opamp is HA17458 and program is visual analyzer my hardware was GEOFEX audio probe to Alto S-6 mixing console to M-Audio Delta Audiophile 2496. I Will have to try reducing the amplitude and see what happens.
Janne
gez
OK, page 6 of the data sheet (output swing vs supply voltage):
http://www.ortodoxism.ro/datasheets/HitachiSemiconductor/mXwvwss.pdf
At 9V supply the available output swing is close to the peak-to-peak amplitude shown by your scope.  The distortion is probably that caused by the amp saturating as it approaches its limits.  Presumably there's still enough travel when saturated to be able to trigger the Schmidt and prevent latching.
Definitely reduce the 47k and hopefully things will clean up.
What worries me about the screenshot, is that the 'distortion' - which may either be a genuine representation, or else an artifact of the measuring equipment - is different, from one cycle to the next.
That makes me pretty suspicious :icon_confused:
gez
Quote from: Paul Perry (Frostwave) on March 11, 2008, 05:44:08 AM
This could well explain it, Paul:
Quote from: jpm83 on March 10, 2008, 03:53:05 PM
(my highlight).
About 10X (easily) the frequency you'd want, unless that comma is supposed to be full stop?  Would need to see the other resistor values used to do the calculations.
