Piezo Transducer Electronic Bypass.
Started by nelson, March 07, 2008, 12:53:17 PM
nelson
Switches are relatively expensive, wear out, are big, clunky and are murder to get if you aren't in one of the G8.
So, I present the Piezo Bypass.
Basically working on the same principle as you do to create a drum trigger out of them, you can use them as a bypass touch sensitive footswitch.
I got my ideas from the wicked switches article over at TTG's site and Music from outer space synth pages.
At 12 pence a pop for tiny piezo transducers and pennies for a bit of rubber and foam to go over the transducer on the enclosure, it might be worth messing around with.
My project site
Winner of Mar 2009 FX-X
