Removing Grungey Velcro from Vintage Pedal
Started by zombiwoof, March 15, 2008, 02:28:35 AM
zombiwoof
I recently scored a really nice original MXR 6-Band EQ from Ebay for $50, it's in pretty good shape considering the age.  Tried it out tonight through a friend's Hot Rod Deville, on the clean channel, and it made a mediocre sounding amp (it needs tube and speaker upgrades) sound unbelievable!.  I guess it didn't hurt that I was playing his '61 Les Paul Junior (SG shaped body) with Bigsby through it.  Now I see why guys use these things, I've been playing for 30+ years and never really used an EQ pedal of any sort.
Anyway, to get to the subject, it has some really worn-out Velcro on the bottom, and I wondered if anyone had any tips on removing that stuff without taking the paint off the pedal.  I've never had this problem before.
Thanks,
Al
jefe
Scotch 6042 Adhesive Remover?
I've never used it to remove velcro, but I have used it many times on tape & sticker adhesives. Works like a charm, and it's citrus based, so it'll leave your pedal smelling like an orange.  :)  The pen dispenses the liquid through a felt tip that you press down to make the liquid flow. You could let some liquid start to flow under one edge of the velcro, peel it up a little, apply a little more liquid, etc. Then clean up the remaining adhesive.
John Lyons
Naptha works well and you can use if for cleaning/degreasing boxes and a lot of other uses.
Pretty mild as far as eating pain once it's cured and gets the stickies off most things without taking paint off.
John
Basic Audio Pedals
www.basicaudio.net/
BubbaKahuna
WD-40 removes virtually any adhesive and does nothing to any paint I've ever used it on, especially baked paint like used on commercial enclosures.
There's also a good product called Goo-Gone which also does the same thing, but costs more than WD-40.
Cheers,
- JJ
My Momma always said, "Stultus est sicut stultus facit".
She was funny like that.
zombiwoof
Thanks for the ideas, I've got naptha, and my roommate has some goo-gone, I'll try those first, just wasn't sure either would leave the paint intact.
Al
Dragonfly
Blowtorch, crowbar, and a pickup truck !  :)
Mick Bailey
I've also used WD40. Leave it overnight. Test the edges and see if they lift - if you feel resistance as it peels back,  spray a little more under the edges and leave it again until it comes away easily. Patience is the key to success.
Ed G.
Add Pam non-stick spray to that list.
Non-pedal related: It's great for getting tree sap off also.
8mileshigh
Quote from: Ed G. on March 16, 2008, 08:21:16 PM
Ah, maybe I can try that one my cat, he's had pine oil stuck on his back from the Xmas tree since mid December  :icon_smile:
Chris
Builts completed: Tweak-O, Fuzz Face Si and Ge, Rangemaster,Fuzzrite Si & Ge, Bazz Fuzz, L'il Devil Fuzz, Bosstone one knober, Bosstone Sustainer, Cream Pie, Kay Fuzztone. http://www.myspace.com/chrisdarlington
Paul Perry (Frostwave)
earthtonesaudio
chindog
Beer.
Don't put it on your pedal.  Just drink it while you are trying the other stuff.
Mike H
