Small Clone SAD1024 version, diodes?
Started by sfx, March 24, 2008, 12:20:33 PM
sfx
Hi everyone,
I am planning on building a Small Clone-clone based off the excellent Tonepad PDF thats available. However I would like to try using SAD1024's instead of the MN3007's simply because I have a couple of them kicking around being unused at the moment.
Anyway, I was comparing the differences between the SAD1024 and MN3007 versions of the pedal, and noticed that the SAD version of the Small Clone has a couple extra diodes in the circuit (see schematic below for differences)... My question is, are these extra diodes just more 1N914's? or are they something different?
http://www.tonepad.com/fpstuff/smallclone1024.gif
Also, if I were to do the stereo mod from the Tonepad schematic as well, I assume the pedal would function as a regular Small Clone if it were hooked up to just one amp (mono), is that correct?
Any thoughts/help would be appreciated, thanks.
sfx
