Glue gun vs JB weld vs Epoxy on alu cases....which is best?
Started by momo, April 04, 2008, 10:31:22 AM
momo
Quote from: juse on April 04, 2008, 05:19:36 PM
Quote from: momo on April 04, 2008, 04:51:36 PM
Wow Juse, did you do that custom for the tread? :icon_eek:,
Yeah, I did it when I was supposed to be working.....  :icon_wink:
Seems doable, I've been wanting to try it myself, so this gave me an opportunity to think about it. I like the idea of setting the controls & not worrying about if it gets bumped & turned somehow - at least for a pedal like an od where I don't change it anyway after it is set.
Well I like the idea of a ex bias on a rangemaster for when you use it directly on a tube amp, tweak it perfectly for those particular tubes....Or I guess when it gets real hot and the germs fall out of the sweetspot.
"Alas to those who die with their song still in them."
juse
Quote from: momo on April 04, 2008, 05:55:31 PM
That's good thinking, Mario. More good reasons to give it a go.
birt
oh did you ever try double sided tape? the 1mm thick foamy type will be perfect for what you are trying to do
http://www.last.fm/user/birt/
BubbaKahuna
That's exactly what I was going to say - double sided tape.
It comes in different strengths so get the strongest stuff you can find.
Mount the L-bracket posted earlier and tape that to the enclosure.
You could also use JBWeld to attach the L-bracket & I doubt very much that it would go anywhere.
I've also used it to fix a cracked engine block and it held well enough to not only fix the crack, but be drilled and tapped for a head bolt.
Mix it right and follow the directions and it's unbelievably tough stuff.
My Momma always said, "Stultus est sicut stultus facit".
She was funny like that.
Shepherd
DougH
Quote from: birt on April 04, 2008, 06:17:49 PM
Yuck, I've had nothing but trouble with double-sided tape.
I agree with the bracket idea. Nuts, bolts, screws will always trump glue and tape. The only thing I use hot glue for is to glue in some foam to hold the battery in, a la the old MXR boxes.
