GGG LPB Help - Switch Problem?
Started by iamspartacus, April 05, 2008, 10:39:12 PM
iamspartacus
Hey guys.  I'm having something funny happen to my LPB build from GGG.
http://www.generalguitargadgets.com/index.php?option=com_content&task=view&id=72&Itemid=26
I bought a RTS board from them and assembled everything this evening.  The substitutions I've made to the values are R1(430k) to 470k, R2(43k) to 47k, and R6(1.5M) to 1.47 (1M + 470k in series).  The Tranny used is a 2n5089 (from aron's shop) that's socketed and oriented correctly.
Here's what's happening:  There's no signal going through the pedal on or off.  However, when I depress the 3PDT switch a little bit, the pedal works fine.  I've tried using a 9v battery and a power supply and the same thing happens with both.
Any ideas?
thanks
Dragonfly
Read the thread directly above yours....
http://www.diystompboxes.com/smfforum/index.php?topic=29816.0
seriously though...you may have a faulty switch... you may have "burned" the switch ...you may have a "solder bridge" on the switch.... grab a magnifying glass and your multimeter !
iamspartacus
My bad.  I totally only read the first half of it :P
Q1
C= 4.6
B= .71
E= 137.6
I'm not gonna lie, the debug original post is pretty confusing to read through.  Is there anything else that you guys would like to know?
I think I'm going to try another footswitch...
iamspartacus
well, it turns out to be a faulty switch.
what a waste of bandwith...
what a waste of $4.50...
thanks dragonfly
Dragonfly
Quote from: iamspartacus on April 05, 2008, 11:39:22 PM
thanks dragonfly
glad you got it sorted out.
bad switches happen sometimes ...
