double overdrive in one pedal
Started by mzapping, April 17, 2008, 06:57:41 AM
mzapping
 how to make one conexion  as this of switch 3pdt
making  a double pedal  in one
somebory  would have a project of 3pdt as this?
ambulancevoice
so do you want to be able to switch between two different overdrives, or do you want to switch between two different settings of the same over drive ("channel" switching)
ConanB
This is the 3rd time you've posted the exact same thing.
Check my reply to both your other posts for an example of wiring 3pdt's for 2 overdrives/fx/whatever in one pedal.
If you want 2 different overdrives the just wire up 2 overdrives in a box using the 3pdt wiring I mentioned in my other replies.
DiamondDog
Quote from: ConanB on April 17, 2008, 08:39:46 AM
Actually, it's the 4th.
Aron, if you're reading this, is it in the FAQ that you should show some self restrain, no matter how much you enjoy posting the same question?
It's your sound. Take no prisoners. Follow no brands. Do it your way.
"Protect your ears more cautiously than your penis."
    - Steve Vai, "The 30 Hour Workout"
Dragonfly
Now I'm starting to sound like Gus....
It's been in my gallery for years....
dschwartz
you can build tonepad´s micro-micro project (stereo microamp) and add some diodes (equals dist +)
then switch between both outputs..
i did that and worked GREAT
Tubes are overrated!!
http://www.simplifieramp.com
GREEN FUZ
dschwartz
well..i´m starting to hear "i´ve got you babe " on the clock radio now  :icon_mrgreen:
