Fet Phaser Idea
Started by mac, April 19, 2008, 11:25:24 PM
jambers
Any one care's to check these PCB's of it?
I've made 2, in consideration the pinout of the fet's or bjt's.
LDR are not on the picture, because I have no library of them. But you can clearly see the where they have to be put; right across the led's.
Suggestions of comments are welcome, since this is my first attempt on making a PCB that's more then a few resistors, capacitors en trannies.
I also used a dual gang pot for the 'Regen', since I think that's what is being used. But I could be wrong
gaussmarkov
Quote from: jambers on April 30, 2008, 04:02:19 AM
o.k.  i just updated gm-resistors.lib to include a 5mm LDR like the old Mouser 338-54C series or a Selco 8P series component.  i haven't double-checked but it should work fine. :icon_wink:
mac
Please, before making a PCB, I guess it is better to wait for users breadboarding it, and hear their suggestions and mods.
Also, I´m still experimenting: single big LED and BJTs.
jambers,
Did you bradboard it?
mac
dschwartz
mac..what´s the current state of this?
i´m very interested in this..like someone said before, is so nice to have something different than a fuzz or a TS variation to discuss.
the circuit is beautiful in its simplicity and tweakability..thanks for sharing!!!
Tubes are overrated!!
http://www.simplifieramp.com
mac
I have a deadline in a couple of weeks so I did not have much time for experiments.
Actually I have a both a BJT and FET version on breadboards.
- BOTH: too many regen path. I guess just one going to Q3 base is enough.
- BJT: I want to increase the BJT impedance to have a deeper effect, so I guess I have to use darlingtons. Anyway the regen path restores any loos caused by Z-in.
- FET: I tried placing the LDRs at the drain with the 100k, and the 103 cap at the source in 2 fets, and leave the other 2 unchanged. Just for fun.
I found a little annoying effect at very low speed, when the LEDs go out the signal level increases noticeable. I have to work on that. The BJT version seems a little more consistent about this.
mac
dschwartz
you mean when the voltage on the oscliator goes lower than 0.7V and the led goes out, then there´s a loud sound..or that the lower the light, the higher the volume, like a tremolo thing?
if it is the 1rst, then adding a little dc bias to the led would soften the response (like adding a 1V bias voltage)
if second...maybe the balance between the inverted and non inverted parts of the filters is not ok..
or maybe, as somebody said before, i don´t see the clean signal bypassing the filters, as all the other phase designs i have seen..
you can couple A FET and a bjt to get low output Z and high input Z..
Mick Bailey
You could drive a lamp with a suitable power transistor and get some bulb latency in there!
mac
Quoteif second...maybe the balance between the inverted and non inverted parts of the filters is not ok..
Yes it is more like a tremolo.
Most likely it is a balance thing, but i am going to connect the mix pot in the usual way: wiper to Q5 gate, other two to Q1 gate and last 104 cap which must be disconnected of Q5 gate.
Quoteyou can couple A FET and a bjt to get low output Z and high input Z..
I thought about it, like in the booster I posted long ago: a fet buffer direct coupled to a bjt. But I have to add 4 more bjts :S
dschwartz
Quote from: mac on May 09, 2008, 12:12:42 AM
yup, that wil kill the simplicity beauty of it..
it´s possible tu make a phase shifter with a cmos phase inverter?
TELEFUNKON
you can even use a transformer!
mike_a
Hey mac,
any news on this lovely project?  :icon_wink:
did you decide which way to go (i.e BJTs or FETs.)?
Cheers,
Mike.
Gus
You can try the univibe bootstrapped darlington stages, make the transistors a single modern darlington
dellamorte
this looks like a good candidate to hook up to a vanishing point :)
Built=SHO,DOD 250,Atari punk console,Fuzz Factory,Easy Vibe,Burning Crunch,Modded Vm fuzz (2n5088+bmp tonestack),Wah Probe,Wooly Mammoth,Eternity,Big Muff Tri
Up Next = ???
Eventually = Firefly, rackmount L5 preamp
http://dellamorte.gofreeserve.com
mac
Quotethis looks like a good candidate to hook up to a vanishing point
:icon_cry:
Hopefully I'll resume soon.
QuoteYou can try the univibe bootstrapped darlington stages, make the transistors a single modern darlington
Gus, I thought about darlingtons.
BJTs work and their bias are more consistent, and darlingtons can easily replace those univibe bootstrapped transistors. Making Zin over 1M will ensure the same results I got with fets... teoricamente :D
Maybe 10Ks at C and E, and a >4M7 from B to C. Even 15ks to reduce current draw.
Besides I want it to work with a single big ultra bright led as Miguel suggested. I was wondering which color to use. Human eyes are more sensitive to some freq than others, yellow IIRC, at the same intensity. LDRs might behave the same.
mac
bioroids
You should check the specification of the LDRs you are using. The ones I have here, I don't remember how many nm were, but I remember they matched the best with Orange Leds, and second with yellow Leds. I'm using Red leds anyway, because that's what I have in hand. As a matter of fact I'm using one regular 5mm diffused led for 4 LDRs, and it works just fine.
Regards!
Miguel
Eramos tan pobres!
mac
mike_a
To my knowledge, all LDRs sensitivity peaks at around 590nm-630nm (wavelength).
That would make orange and yellow LEDs the best candidates.
I would go with ultra-brights as they have a larger light intensity swing, which would in turn lead to a larger resistance range of the LDRs.
Regarding the darlingtons, I would suggest trying MPSA14.
They should have very high hfe.
DougH
Looks nice! (Somehow I missed this thread.)
Sounds good too! Nice job. :icon_wink:
  This is now the little added 'Accolades' section of the smart thread...
  Nice schematic ! Nice Soundclips ! A departure from what I've seen phaser schematics look like from before...making headway...'less finicky' about components is a good feature.
mac
I'm considering to separate fet and bjt versions on different linked threads.
I'm breadboarding the BJT version using bc549c hfe=500. 10Ks at E and C, 4M7 from B to C. Vc is near 6.3V. 2n5088/9 can be used too.
If a single LED works then I'll test it on the fet version as well.
mac
