Insanity Box can use CD4069 instead of CD4049?
Started by rogeryu_ph, April 23, 2008, 10:09:11 AM
rogeryu_ph
That's the question ???  Errr one more, Does it really sound G3 as it indicated on schem.
Calling Aron :icon_biggrin:
Roger
demonstar
I don't see why this substitution should be a problem but I don't have adequate knowledge to say for definite. The pin out is different so it certainly wouldn't be a direct sub into a PCB or layout. The layout would need changing to cater for the new pinout.
"If A is success in life, then A equals x plus y plus z. Work is x; y is play; and z is keeping your mouth shut"  Words of Albert Einstein
aron
I have never used the 4069. I suppose if it is a replacement for the CD4049UBE it should be fine.
Yes, it does a lot of distortion and sustain for sure.
aron
rogeryu_ph
What guitar, AMP and other pedal if there is did you used on the sound clip? Also what kind or category of distortion is Insanity?
Roger
