Which Capacitor is which!!! please help!
Started by DanAngus, April 23, 2008, 09:25:55 PM
DanAngus
Hey Guys,
I have a question.
Im brand new to this stuff, and i need a .15mf electrolytic(or similar) capacitor.
I got 2 capacitors, i have been told that one of them will work
One is a .15mf Panasonic capacitor
and the other is a 15mf electrolytic capacitor(i think)
lol
but Aron said that the .15 mf panasonic would work.
but theres one problem.. i just got my box of supplies from small bear in today. but i guess they would think that i know the difference between the 2 capacitors. But i have no idea!
so hears some pictures, and would you guys be able to tell me which one is the .15mf Panasonic capacitor?
Thanks alot(sorry about the blurryness/ picture size)
Minion
Showing us a Fuzzy picture of a Cap isn"t going to help us help you very much...Capacitor Values are determined by the Code written on the Capacitor, Every small Value Capacitor will have a 3 number code written on them followed by a letter or two....
Here is a Code calcultor that will tell you the Value of the Cap based on the code written on the Cap....
http://www.muzique.com/schem/caps.htm
Cheers
Go to bed with itchy Bum , wake up with stinky finger !!
Papa_lazerous
The orange cap is a tantalum cap,
the other cap is a film cap, that'll be your panasonic one
dxm1
Quote from: Papa_lazerous on April 23, 2008, 09:48:37 PM
The one on top in the first photo...
The larger,square one on the bottom in that photo.
demonstar
Make sure you connect the tantalum capacitor the correct way around because I heard those things can go off like fire crackers!
If you already knew that, sorry, I didn't mean to be patronising. Just figured worth pointing out considering you were asking about which cap is which. It's not good when it all ends in tears and a mess.
"If A is success in life, then A equals x plus y plus z. Work is x; y is play; and z is keeping your mouth shut"  Words of Albert Einstein
DanAngus
Quote from: Minion on April 23, 2008, 09:31:18 PM
Cheers
Welll im sorry, see i didnt know that the numbers had any significance.
Quote from: demonstar on April 24, 2008, 03:50:00 AM
Yes, i didnt know that, but im going to use the panasonic Cap. thanks for the reply!
Thank you very much!
GibsonGM
The numbers are significant, but there are a few different methods of labeling those suckers!!    2 digits, especially if underlined, usually mean pF (ie, 10 = 10 pf, typically a pretty small cap physically, too!).
The 3 digit codes are read like a resistor in a way, and the scale "starts" in the pF range; the first 2 are your figures, and the last is a multiplier.  So, a cap reading "221" would be 220 pf.
"472" would be 4.7 nf...."123" would be 12nF.  This is due to an implied 10 to the power of {insert multiplier here} *  the first 2 numbers.   Like, 47*10^2 = 4700pF, = 4.7nF after you move the decimal 3 places left to convert to nF.
Pretty crappy, isn't it? Using that cap calculator helps a lot!   The "plastic" ones, such as yours there, typically have their value right on them, like ".15" for 150nF, which is the same as .15uF.   You'll get the hang of it!
;o)
Grizz
This link won't tell you the value but it will help you identify your part.
http://www.generalguitargadgets.com/index.php?option=com_content&task=view&id=31&Itemid=27
This link is from general guitar gadgets, if you havn't checked them out yet do it...it's helped me out a lot and check out the wiki from this forum.
