MKII pedals, germanium and outdoor weather...
Started by Orpheus, April 27, 2008, 12:11:42 PM
Orpheus
Hi, all.  I played an outdoor show last night and it was right around 50 degrees at showtime.  I have an MKII tone-bender type pedal with the standard three germanium transitors.   Well the pedal started fading and then it would not work at all during the show.  I know germanium is temp sensitive, but is that normal for an MKII to just stop working at 50 degrees?  There is a bias control inside too - would adjustment have helped (didn't have time to open it up and adjust during the show of course)?  It works fine now at normal room temp...
Thanks much,
-Mike
I don't know that this was the entire problem with your pedal. It seems odd for it to completely quit. Usually I would expect the sound/tone to drift away from how it sounds at room temperature. But it's not unknown for germanium to drift a LOT, so it's possible that it was all temperature drift. Has it drifted back to working now that it's warmed up?
There's no way to say whether or not it's normal for a MKII or any other Ge pedal to stop working at 50 degrees. It depends too much on the particular devices inside.
Orpheus
Quote from: R.G. on April 27, 2008, 12:16:56 PM
Thank you, R.G..  It works fine again now at room temp.  I will also specify that I had it adjusted at midpoint on the internal bias pot - right in the middle, so bias was lower than average to start too.
Timebutt
I can confirm the Mk II is very sensitive to temperature changes: when I was working on my circuit the other day all of a sudden I noticed the sustain and tone were not right: notes were fading out in a very odd way. When I measured the voltage on Q3 I got something way off -4,5V as I had biased it: apparently just because the circuit was lying in pretty intense direct sunlight the biasing changed. The same happened when breathing on the transistors: weird things with sustain etc.
Incredible pedal nonetheless :)
Completed Projects: Gus Smalley Booster, Modded Russian Big Muff, Orange Squeezer, BYOC Vibrato, Phase 90
  Yes, GE's can drift alot...
  I had a 'theremin' going in an octave pedal, the pitch controlled by the heat of the GE as influenced by touching it with just the thumb on it's top !
  TBMkII, was unusably biased in the hot sun, also when it came in from freezing, those same TB's sounds fine if not too hot, not too cool.
  But I think they were probably biased near an 'edge', and a bias tweek in some cases can allow much wider temperature functioning...ie keeping the bias 'centered' means it takes more drift to push it past a 'parameter' which causes misbias.
Orpheus
Quote from: Timebutt on April 27, 2008, 03:37:38 PM
Thanks for sharing, Timebutt.  That is exactly what I noticed - notes fading in an odd way at first, but then after it got colder it completely went silent...
Orpheus
Quote from: petemoore on April 27, 2008, 03:43:26 PM
Interesting!  Well I decided to put the bias back near max on the trim pot.  It sounds a lot stronger there anyway, and in retrospect I don't know how I managed to think the pedal was sounding good with the bias I had it adjusted at earlier.  Thanks!
zombiwoof
A good reason to put the bias control on the outside of the pedal, as many have concluded.
Al
