Enclosure Etching Time
Started by carrejans, May 05, 2008, 07:25:18 PM
carrejans
I'm going to etch an enclosure for the first time. I'm going to use NatriumPersulfat (SodiumPersulfat).
How many grams should I use? (about 50g ?) And how many water?
Most important question: How long do I have to etch? (without any heating) (any experiences?)
Thank you!
danielzink
Don't know if it'll help or not...
but I used Ferric and it took about 3 or 4 minutes (total - what with rinsing and re-dipping etc.)
Dan
~arph
I don't know about natrium persulfate, but I do know that amonium persulfate will NOT etch aluminium..
I'm not a chemist so I can't tell if there will be a reaction.
Regards,
Arnoud
ambulancevoice
no, sodium persulfate wont work on aluminium, no persulfate solution does
it can be used as a substitute for ammonium persulfate on etching zinc or copper (pcb)
id try get another chemical that has been used before by others
like FeCl3 (ferric chloride, has been used ALOT succesfully) for example
search the forum for aluminium/enclosure etching (search button above)
carrejans
Thank you guys, for telling me that persulfate can't be used for etching aluminium.  :-[
Today, I bought Ferrichloride Hexahydrate. I think this will etch aluminium.
So, how many of it should I solve in water; and what would be te time to etch?
Thanks...
ambulancevoice
Quote from: carrejans on May 07, 2008, 02:46:24 PM
Thanks...
well, i couldnt find any info on turning the FeCl3 crystals (which im assuming you got) into a solution using water
you can buy it in liquid form
anyway. here is an etching tutorial you MUST look at
http://www.aronnelson.com/gallery/main.php/v/MarkMs-Gallery/album24/
12bar13
Quote from: ambulancevoice on May 08, 2008, 03:01:38 AM
what kind of paper is he using? i've been using photo paper and i can't get a good transfer for the life of me.
ambulancevoice
its called Press And Peal, or PnP
its a special paper for this kinda stuff
12bar13
where can i buy it? is it something that typically can be found at a store or am i gonna have to order it?
carrejans
Thanks...
I already found the tutorial of MarkM; very good one. Thank you.
I will do a search on the Internet for correct measurements of the crystals and water.
carrejans
Quote from: 12bar13 on May 08, 2008, 03:52:20 AM
The regular effect-supplier-shops on the net have the Press-n-Peel papers. (Banzai, SmallBear, ...)
But I heard glossy photopaper will have the same effect. But don't forget to use a laserjet (or xerox) and not an inkjet!
12bar13
i am having no luck with the photot paper. at least with enclosures, its can't miss with pcb's. i can't get a consistant transfers across the whole thing no matter what i do.  i'm deffinatly gonna have to order some PnP.
carrejans
In the meantime I have ironed the pnp on my enclosure. I notice that there are some really small air bulbs under it. Is that really bad?
The transfer wasn't perfect; so I did some pieces with a black waterproof pen. (for writing on cd's) Will this be ok?
Thanks.
ambulancevoice
Quote from: carrejans on May 09, 2008, 12:35:10 AM
Thanks.
those are air bubbles most likely, your supposed to (as per the tutorial) push those into the cut out areas so they dont mess with the transfer
also (as per the tutorial again) try use paint (unless they are tiny touch ups then you can use a pen) to fix up areas on the mask, ink doesn't withstand the acid as well as paint does
Paul Perry (Frostwave)
nail varnish is good for touchups.
Also it comes with a little brush  :icon_wink:
Curiously enough, persulphate is one of the chemicals used to form an oxide layer on aluminium when making electrolytic caps! so I guess it won't etch your box.
carrejans
I don't have paint; but the missing pieces are really small.
I didn't notice the air bubbles while ironing. Will it effect the etching a lot?
@ Paul: I bought ferric.
markm
Air bubbles are a weak spot in the mask.
My advice would be to touch it up before dunking it into any type of etchant.
ambulancevoice
oldrocker
frank_p
Quote from: ambulancevoice on May 09, 2008, 08:04:31 PM
are you back Mark?
Quote from: markm on May 09, 2008, 04:00:56 PM
He killed Zorro and came back !  What a fine shooter.
