whats inside the foot switch?
Started by REGNAD, May 10, 2008, 10:53:53 AM
REGNAD
i have a footswitch from GGG. it has 9 pins on it. Is this a 3pdt switch with commons in the middle?
regnad
GibsonGM
I believe so, REG.  Try testing the continuity of the poles using your DMM.  It's easy to misorient the switches so they're turned 90 degrees and don't function correctly ;o)   Typically, the flat blades are looked at so they're running horizontally...then the commons are middle, and poles are top & bottom from there.  Each up/down row is it's own pole, so you of course get 3 separate switches at once.
