Re-amping box 1k:1k transformer?
Started by newb, May 12, 2008, 02:54:12 PM
newb
im wanting to build a reamp. I only have a 1k to 1k transformer
can i use it?
bancika
Taking output signal from one amp and amplify it with the other.
I'd say it's better with isolation transformer because you're safe from ground loops.
Pushtone
Quote from: petemoore on May 12, 2008, 03:04:57 PM
  What's a reamp ?
To me, Re-amping is when you pass a signal from from a recorder back into an amplifier and re-record the amp.
http://www.radialeng.com/di-xamp.htm
Paul Marossy
#4
Your bigger problem will be finding an audio transformer that does better than 300Hz-3kHz. You could improve the frequency response some by using an opamp driver. There's some good info in this thread about audio transformers for use with guitars: http://www.diystompboxes.com/smfforum/index.php?topic=40603.20
Or you could look into using a Jensen transformer, but it's like $100. http://www.jensen-transformers.com/apps_sc.html
brett
Hi
I've never tried this, but in theory it could work.
The frequency range of audio transformers is limited at the bottom end due to a lack of inductance, and the roll-off is similar to most 1 pole filters (ie 6dB per octave).  You could use a graphic equaliser or a simple bass boost circuit to boost the bass by this amount.  At the top end, the losses are more complex, due to poor capacitive coupling and other stuff I don't really understand.  However, the same princliple applies.  A graphic equaliser could be used to compensate for the losses and achieve a more balanced sound.
Heck, I just had an idea - what if you put one of those transformers in the feedback loop of an op-amp.  Would that give gain that is the mirror-image of the transformer's response?  Or would the losses be too great at the amount of current operating in the feedback loop?
cheers
Brett Robinson
soulsonic
Edcor makes awesome quality small audio transformers for all kinds of applications like this and they can wind custom ones for a very reasonable price. I've used one of their 15K:15K ones to give an isolated out to an A/B box and the sound quality was superb!
And their prices are dirt cheap compared to Jensen and Lundahl!
Please check them out; I guarantee you will not be disappointed.
http://www.edcorusa.com/home.html
This is the one I used in my A/B box:  http://www.edcorusa.com/products/transformers/pc/pc15k-15k.html
Those specs are no joke!!!
Stop messing around with those garbage telephone transformers and start using the real thing.
Paul Marossy
QuoteA graphic equaliser could be used to compensate for the losses and achieve a more balanced sound.
I thought of that, too, but I have never personally tried it. It makes sense in theory, though.
QuoteEdcor makes awesome quality small audio transformers for all kinds of applications like this
RG had mentioned that before. I should pick one up to give it a try...
PerroGrande
+1 on checking out Edcor.  I just spent some time on their site this morning, and their stuff looks fantastic and very reasonably priced.
Can anyone say "economic stimulus"?  Sure... I knew you could...   ;D
soulsonic
Here's a pic of the isolated A/B/Y I did:
That transformer is so beautiful!
And heavy too! :)
Paul Marossy
Looks like a quality transformer.  :icon_razz:
jmasciswannabe
Check this out:
http://messageboard.tapeop.com/viewtopic.php?t=7319&postdays=0&postorder=asc&&start=15&sid=bf4800f923a16e0230fd720771bf5006
I know it doesn't use your transformer, but if you want to build a diy reamp, that seems like the inexpensive way to go. The transformers are a bit large though. Make sure you have a deep enough enclosure. I am planning on using a radio shack plastic enclosure that cost me $4 bucks. I am going to shield it if it hum.
Hopefully, there is no rule against plugging tape-op....fantastic magazine and forum! Cool mic and preamp mods!
....the staircase had one too many steps
