AMZ Mosfet Booster: works, but little gain
Started by carrejans, May 13, 2008, 03:25:41 PM
carrejans
I built the Mosfet booster from Jack (AMZ). It works, but not like I wanted. The increased gain is really low.
Is this normal? If so, how to increase the gain?
Does the 5k pot needs to be log or lin?
Thanks...
another question; I bought a BS170P from Zetex, but lost it; so I used a normal BS170. Will the Zetex make a lot of difference to the tone, you think?
(High quality, low noise version of the standard BS170 with exceptional characteristics. Made by Zetex.)
markm
use a 5K reverse log pot for optimal performance.
alanlan
carrejans
Quote from: markm on May 13, 2008, 03:31:11 PM
Nice tip, thanks.
Ik think I used a 5k log. Jack probably meant a 5k lin, right? That is probably the problem here.
carrejans
alanlan
Still, check your biasing.  There is no trimmer but the bias resistor values are initial/nominal and should be adjusted according to your preference for biasing.
johnny5
I built that one and thought it had plenty of gain. I also thought it didn't sound very good. I turned it into a rangemaster and think it's now one of my favorite pedals.
JFX09
I think it's not supposed to "sound good", it's designed to be a transparent (not adding any color to the tone) booster.
Happiness is a effin' hot soldering iron
markm
Ya know, I fergot about this.
Added a trimpot to adjust the bias of the BS170.
