Tube Driver Debigg (Please Help!)
Started by kurtlives, May 13, 2008, 06:11:48 PM
kurtlives
I know you guys probbly always get this but I am sure I have things wired up correctly.
I have built a GGG Tube Driver. Only mod is I added a bias knob. For the life of me I cant get it to work. I had audio but the pots didnt work like they were soposed too or didnt work at all. Now when I test it I get no audio. Bypass works and I am getting 15V to the PCB.
Voltages...With tube in and pedal ON.
1. 5.40V
2. -2.79V
3.-2.69V
4. 0.01V
5. 0V
6. 3.61V
7. -2.77V
8. -2.69V
9. 0V                          Btw the tube does glow and get warm.
IC.
1. 0.03V
2. 0.03V
3. 0.03V
4. -2.67V      Seems too low
5. 0V
6. -2.24V
7. 11.85V
8. 12.52V
My DIY site:
www.pdfelectronics.com
dschwartz
that would be a magic tube cause there's 0 V at the heater pins...
Tubes are overrated!!
http://www.simplifieramp.com
kurtlives
Well it does glow....weird....Anyone?
My DIY site:
jjs
There is 0 V DC across the heaters. They are connected to 12.6 V AC it seems. So this is allright.
The -2.67 V for V- is too low. I would search in the power supply for some error. Maybe measure V- again with the tube and the IC removed (or measure the power supply seperately if possible). Maybe this helps.
MikeH
Looks like pins 6 and 1 of the tube should be the same voltage, and they're not.
kurtlives
Ok I have isolated the problem...
With the tube in and notthe IC the V+ is 14.5V and the V- is -14.5V.
Now with just the IC in and not the tube the V+ is 14.5 and the V- is -2.67V.
So the problem lies in the op-amp section. Anyone have any ideas?
My DIY site:
