Looper with 3 loops
Started by mnordbye, May 19, 2008, 09:18:29 AM
mnordbye
Is there any project like it? I friend of mine want me to build something like this: http://finn.no/finn/viewimage?finnkode=13407711&reference=1/134/077/11_-1130435254.jpg&adheading=Catalinbread+BacaLooper&sid=xz6cbaD1HqA541361&adTypeId=67&WT.svl=Hovedbilde , but he wants to have 3 in one box instead of 3 different boxes. Would it be as easy as adding 3 of these: http://www.generalguitargadgets.com/index.php?option=com_content&task=view&id=216&Itemid=26 after each other?
Magnus Nordbye
General tone addict
Deaf Audio at Facebook
ayayay!
It's all here:  http://www.singlecoil.com/tb-strip/tbstrip.html  <-Read about cascading loops.
I found this using the search button.   ;)
The people who work for a living are now outnumbered by those who vote for a living.
mnordbye
Thanks, suppose i forgot the almighty search button. :)
Anyway, no buffers are necessary i guess? Since the pedals probably have them anyway..
One more thing, if nothing is connected in one loop, and i switch it on, will it work ok for a mute switch?
Magnus Nordbye
General tone addict
mnordbye
General tone addict
B Bent
Quote from: mnordbye on May 20, 2008, 11:18:59 AM
'bump'
Yes it will. I had a 5 looper and I used one port as a mute.
mnordbye
Cool, thanks for the reply!
Magnus Nordbye
General tone addict
SolariEGO
Hi Magnus,
To avoid hum, I think you'll want a switched jack for that, wired so that when there's no jack in the input of the loop, the input is shorted to ground. I think Banzai carry them. If you have a fender amp, you could look at the speaker output to se how it's wired (Fender does it to avoid frying the output transformer if you fire the amp up without a load, ie a connected speaker).
By the way, is that you selling those sharp looking pedals on finn.no?
Steinar
Rockin' in the Axis of Evil
