Does anyone have a genuine mxr micro amp?
Started by tehfunk, May 20, 2008, 02:30:11 AM
tehfunk
If so, can you take pictures of the component side of the circuit board, I can't seem to find pictures of the micro amp circuit board anywhere, just the schematic. BTW, I just wanted to see it out of curiosity. The pictures would be much appreciated! Thanks!
Carvin CT6M > diystompboxes.com > JCM800 4010
The tools of the artist give you a chance to twist and bend the laws of nature and to cut-up and reshape the fabric of reality - John Frusciante
Auke Haarsma
I have one. If no one does it before I get home, I'll take a pic for ya. My day just started....so you have to wait a couple of hours ;)
tehfunk
tehfunk
Auke Haarsma
Here are some pics:
Hope this can be of any use to you!
Dragonfly
in case you prefer the "original version", here's a picture I took of my old micro amp a while back....
tehfunk
thanks, both of you. Auke, what IC is in your micro amp, and what about in the original, dragonfly? Thanks!
sshrugg
Wow! The guts in the original version are NASTY looking!  Makes my amateur bedroom builds look better : P
Built: Fuzz Face, Big Muff Pi (Stock), Distortion + (Germanium and Silicon versions)
Dragonfly
Quote from: tehfunk on May 22, 2008, 06:38:11 PM
TL061, IIRC...
Auke Haarsma
tehfunk
Quote from: Auke Haarsma on May 23, 2008, 02:30:03 PM
UA741CP in mine.
I don't know about the tl061, but am I right that the 741 is a single op amp? If so, that's interesting because in the pictures thread when i posted the breadboarded mxr micro amp i used a dual op amp and some people said they had always wondered why the schematics for the micro amp call for dual op amps because it's a waste. (I think that's what they said) Anyway, that came off in a very confused way, but yeah, I just wanted to make note of that.
rogeryu_ph
Auke and Dragonfly hi,
Just planning to replace my mosfet booster due to annoying HISS....
Does your microamp a quiet one? When microamp set into level you desire and your not playing and the AMPLIFIER is set into mid volume can you hear any noise? HISS or HUM?
Appreciate your help on this :)
Roger
tehfunk
I just built one, finished it tonight, did not hear any hissing or noise when using it... it's a nice little booster.
Auke Haarsma
it's a pretty clean, lifeless booster. Definately not my favourite. I just happened to have it ;)
However, the mosfet boost should be pretty quiet. Are you sure the hiss is caused by the mosfetboost?
arma61
Quote from: Auke Haarsma on May 24, 2008, 04:15:23 AM
+1
I have the same problem with almost all my buildings hiss and/or hum, so, when they're ready to test, I bring them to my friend home, and when we use them there his garage, hiss and hum are not there anymore, but they're there again when I'm back to my home!, so it must be something in my home (earth connections) or it must be because I test them close to my PC (monitor, printer...), so I'd suggest to try with different setups in different places, don't give up  :)
Cheers
"it's a matter of objectives. If you don't know where you want to go, any direction is about as good as any other." R.G. Keen
rogeryu_ph
Guys,
At our practice venue also the same :-\
I even pull out the mosfet and power up the circuit and plug into the AMP with mid volume AMP is just the same level of HISS... I think it's not the mosfet... Before I never notice this but after band break and I left my amp still on then came back afterward and found out this hiss...When i get home i did re test with my 65w amp on mid volume set up and realize its the booster . I love this booster so much, it's different with SHO and mini booster that I breadboard before. I can cut through the mix with very sparkling solo.  I tested 3pcs bs170 and 2pcs 2n7000 of course different orientation but to no avail.
Tehfunk when you stop playing and your amp set to just mid volume and with microamp still turn on there is no hiss or hum? Maybe this would be now my replacement.
Thanks guy,
Roger
Barcode80
try the buckaroo boost or the sekovia power booster, or the old standby lpb. the rocket boost in yun's gallery is DEAD quiet, it is basically a rebiased lpb.
Dragonfly
Quote from: Barcode80 on May 24, 2008, 11:49:16 AM
the sekova is also a LPB
Barcode80
rogeryu_ph
