Simple opamp tester
Started by sshrugg, May 21, 2008, 08:22:58 PM
sshrugg
Did a little searching out of curiosity.  I've had two build attempts where I can't find any mistakes.  After checking things like crazy, and debugging for days, it turned out to be bad opamps.
http://tangentsoft.net/elec/opamp-tester.html
That might be useful to some of you.  I haven't tried it yet, but I plan on building one.  If anybody has other ways of testing opamps, post them here!
Built: Fuzz Face, Big Muff Pi (Stock), Distortion + (Germanium and Silicon versions)
cpnyc23
I've been thinking about something like this for a while now... I'm not really a fan of the 'put it in working circuit' method of testing op amps...
I wonder how it would be possible to build one that has sockets for multiple DIP cases (8, 14, 16-pin).  Or would one need to be built for each kind of amp and pinout?
-chris
"I've traveled the world and never seen a statue of a critic."    -  Leonard Bernstein
O
Quote from: cpnyc23 on May 21, 2008, 09:02:15 PM
How come?
#3
  The only non-circuit test I can think would be of any use is checking to see if all the pins are intact.
  You could remove some parts from a gain stage [for instance the DC blocking in/out caps] and have a slightly simpler circuit which could be used to test only DC bias.
  I've had good results with field testing opamps, I've only managed to fry a few, and all the others provided performance consistant with their data sheets..of course I didn't scope them, but trust many others have.
mdh
Quote from: O on May 21, 2008, 09:27:38 PM
How come?
Perhaps because that method can be pretty subjective, depending on the nature of the "working circuit" being used for testing?  A simple go/no-go tester such as the one linked by the OP is desirable to have around.  I remember having breadboarded that very circuit at some point in the past, but I don't remember if it detected any bad op amps.
cpnyc23
I like the go/no go idea b/c I think it is a simple tool for a simple job.  I'd rather throw a chip into a testing device and verify it before firing up a circuit for the first time and see an LED give me the go-ahead.  Otherwise you have to build the circuit, have it not work, pull the chip out, open up another pedal & put the chip in, plug in the guitar and test.  That is a lot of steps.
Necessary? No.  Just personal preference is all.
-chris
scratch
If you can find it, Poptronics, Nov. 2001 has an OP-Amp and Comparator test circuit, go/no-go test, single , dual 8-pin pkgs, 14 pin and 4136 layout quad pkg.  LM339 comparator.
Denis,
Nothing witty yet ...
cpnyc23
scratch - thanks for the tip
spudulike - thanks for the link!
-chris
scratch
I'll try reconnecting my scanner to my PC and see if I can't scan the magazine article, only 3 and a half pages long ...
Denis,
cpnyc23
That would be really appreciated scratch - thanks!!!
-chris
sshrugg
cpnyc23
Wow!  That looks like a really cool & useful project - thanks for taking the time to scan and post those Scratch - above and beyond.
-chris
scratch
I've been thinking of building that myself for a while, but been busy with other (non-stompbox) digital things so haven't had a need, but there have been times where I wondered if my OP-amps were working ...
As long as it's usefull ...
Denis,
sshrugg
Hey!  Thanks everybody for throwing in on this.  Much like I expected, it became a pretty cool thread with quite a few options.  Thank you!
grapefruit
Hi,
I wouldn't really trust the first two circuits shown. Usually when an op amp fails the output is slammed up against one of the rails. If it's the positive rail then the LED will light up anyway.
For a simple tester you could use a circuit similar to the one shown. Use a single 9V supply, arrange the op amp as a buffer or non inverting amp with a gain of say 2. Use a pot as a variable voltage divider to go to the non inverting input of the op amp. As you turn the pot toward +9V the LED gets brighter. The same pot could be used to feed all op amp sections.
Stew.
sshrugg
It seems like none of these would work for testing CA3080's.
Does anybody have an idea for those, other than "throw 'em in a working RossComp"?  ;)
