My (probably not so) new idea for a diy pedal display
Started by ugly_guitar_guy, May 22, 2008, 02:00:00 PM
tommy.genes
Quote from: ugly_guitar_guy on June 04, 2008, 01:22:08 PM
That's fricken brilliant! How did you do that?
Unfortunately, I didn't do that - it's a post from the Make: blog. The underlined words "these photos" in my original post were a link to the blog article.
http://blog.makezine.com/archive/2008/06/denkuri_master_electrical.html
The enclosure is white plastic, and the builder sanded down the thickness in the area directly above the display, which is mounted inside the case. The blog article has a link to a Flickr set with some construction photos.
I at first thought that the display was flush-mounted through a hole in the case, any gaps filled with bondo or similar, and the whole thing sanded flush before applying the final finish. Might still be an idea to experiment with.
-- T. G. --
"A man works hard all week to keep his pants off all weekend." - Captain Eugene Harold "Armor Abs" Krabs
pjwhite
I saw a digital clock that did something similar:
http://www.thisnext.com/item/D66E61DC/Wooden-LED-Clock
No paint on this one -- the LEDs shine through thin wood.
I just finished an LPB - on page 293 of the 'Pictures!' thread - I drilled a hole for the LED but ended up mounting it behind the photopaper I used for the image, so it shines through from underneath a red spotlight. It's OK - a little dim though, maybe I should use a superbright LED next time - or mount it under a white bit!
