Rebote 2.5 problems
Started by macombaland, May 22, 2008, 10:46:13 PM
macombaland
So for my first build I was going to do the beginner project but I told myself "How hard can it be?  Just etch the board, solder the components onto the board and its done".  Well i was wrong.
I have everything assembled and for the sake of troubleshooting I bypassed the foot switch.  I have checked the values, positions and solder joints.  I built the audio probe and poked around for a while.  I finally got the signal through the pedal and out the output.  The problem is that the signal is not affected at all.  I hope someone with more experience can give me some pointers.  Thanks
Morocotopo
Hi there. Read:
http://www.diystompboxes.com/smfforum/index.php?topic=29816.0
People need more info to help you.
Some pointers:
Pots connected right?
IC´s /transistors the right way?
Grounds connected together?
wiring right?
Don´t give up! Hang on there. Leave it for a day or two (clear mind). Follow the schem.
Morocotopo
Morocotopo
macombaland
ok ill try getting all of my voltages tomorrow.
All pots are wired correctly, ICs are in correctly, grounds are all connected.
I did have time to mess around with my audio probe for a while.  I still got the dry signal on output.  On pins 12 and 14, when I turn the delay pot it slows down or speeds up the song that Im playing through it...kind of like speeding up or slowing down a tape player.  When I stop turning the pot, it goes back to normal speed.
macombaland
Battery Voltage – 7.8
TL072:
1 –  1.4      5 – 3.8
2 –  4.25    6 – 3.9
3 –  3.9      7 –7.1
4 –  0.00    8 – 7.8
PT2399:
1 – 4.96     9 – 2.50
2 -  2.48    10 – 2.50
3 -  0.00    11 – 2.50
4 -  0.00    12 – 2.50
5 -  2.6    13 – 2.50
6 -  2.49    14 – 2.50
7 -  .55      15 – 2.50
8 -  .55      16 – 2.50
here are my voltages.  how do they look?
