Neovibe projet
Started by Mich P, May 24, 2008, 04:29:00 PM
Mich P
Just before ordering parts your opinion about those for the builders have already done :
Photocell Silonex NSL-7530
Lamp, Screw Base, 1.5 Volt, 25 ma.
Lamp, 12 Volt 40 ma.
Trimpot 200 or 500 ?
Lamp driver 2n3904 or ?
R48 68,100,150 or ?
2n5089
Thank you
Mich P.
andrew_k
Quote from: Mich P on May 24, 2008, 04:29:00 PM
Photocell Silonex NSL-7530 Yes
Lamp, Screw Base, 1.5 Volt, 25 ma This is too tall to fit in a 1790NS enclosure, so I used the tiny 1.5v 25ma one with wires already attached (SmallBear)
Trimpot 500 Yes
Lamp driver 2n3904 Yes
R48 68,100,150 or ?  whatever the schem says
2n5089 Yes
DiamondDog
Quote from: andrew_k on May 25, 2008, 12:40:41 AM
??? ??? Quoting the Geofex parts list:
lamp bulb- Radio Shack 12V/25ma
The 1V5 lamp worked/lasted?
It's your sound. Take no prisoners. Follow no brands. Do it your way.
"Protect your ears more cautiously than your penis."
    - Steve Vai, "The 30 Hour Workout"
andrew_k
Quote from: DiamondDog on May 25, 2008, 03:46:04 AM
Worked great until I killed it by turning the trimpot too far. Small Bear lists a couple of 1.5v bulbs specifically for the univibe
Mich P
So what about the small bear 12v 40mA ?
Mich P.
