Anyone have info on making a circuit to ramp between two rate pots?
Started by Nitefly182, May 30, 2008, 05:33:21 PM
Nitefly182
Im building a neovibe and would like to have the option of ramping between two rates without an expression pedal taking up a bunch of extra board space. Is there a basic ramping circuit anywhere out there?
This is a Korg Integrator, slews control voltages.
Not sure if its what you need???
The Tone God
Nitefly182
That looks like what I want since it works back and forth between a max speed and the standard rate pot but it says it wont work for a dual speed pot like the one in the neovibe :(
Use a VTL5C3/2, which is an LED/LDR module with a center tap. It happens to do exactly what the Neovibe needs, just not what all dual pots need.
