how would i add a clean blend to a Big Muff?
Started by umcoo, June 02, 2008, 10:17:28 AM
umcoo
Title says it all really!  I'll be using a muff (most likely a GGG Green Sovtek) with BASS, but I'd like to add in some clean signal to help me cut through in a band.  Is this an easy add-on?  Any other alternatives? (Don't really want a TB loop blend pedal by the way!)
slideman82
I think there's an effect called Paralooper, schemo's on the net, dunno if someone already made a PCB, but seems to be easy. Would a 100k blend pot between input and output of BMP (lugs 1 and 3, lug 2 would be the output) could work properly? I haven't tried it, but it's pretty simple! If it doesn't work, you've just got to unsolder few wires.
Hey! Turk-&-J.D.! And J.D.!
ianmgull
Quote from: slideman82 on June 02, 2008, 11:03:49 AM
I'm pretty sure that would cause oscillation problems. You would have to use a buffer to prevent problems with mismatched impedances. I've never built a paralooper but I would imagine that's essentially what it's doing.
The French connection
I know, but the pedal i built does not boost...it just increases volume!
My picture files:
http://www.aronnelson.com/gallery/main.php/v/French+connection/
http://s193.photobucket.com/albums/z4/letournd/Pedal/
Dragonfly
Quote from: umcoo on June 02, 2008, 10:17:28 AM
I did a for "clean blend" + "big muff" and found this thread....
http://www.diystompboxes.com/smfforum/index.php?topic=57628.0
I'd also recommend searching using the terms "clean blend" + "fuzz"
You should find quite a bit of info...
