Signal Splitting Buffer Question
Started by Chris Brown, June 05, 2008, 05:22:20 PM
Chris Brown
Please share your thoughts with the group...
If you are going to build a splitter for multiple fx chains (not multiple amps)... to do something like JD's Parallelyzer
Let's say that you want to split the guitar signal between 6 outputs.... 1 clean, 1 to tuner, and four that will be switched or mixed at the other end of the chain.
The question:
What are the pros or cons of using one good buffer with multiple outputs (Jack's AMZ Super Buffer)  - or -  multiple buffered outputs (Andrew's Super Y 2).
Thanks for you input  ;)
CB
Reference posts:
Super Buffer with added outputs (http://www.diystompboxes.com/smfforum/index.php?topic=44654.0)
Super Y 2 (http://www.diystompboxes.com/smfforum/index.php?topic=9704.0)
Parallelyzer (http://www.generalguitargadgets.com/index.php?option=content&task=view&id=67&Itemid=99)
