Help identifying film cap
Started by SolariEGO, June 09, 2008, 05:34:33 PM
SolariEGO
Hi hackers,
I really like the "brownie"/"chicklet" type film caps that GGG ships with their kits, but I can't find them anywhere. The GGG caps are very compact and I've seen values up to 1mf.
Here's a picture:
The almost cubicle ones (marked L5- 105) are the 1mf caps.
The GGG web site says they're Panasonic, but they're not the ECQ-B/ECQ-E(F) polypropylene film caps from Small Bear (bigger and shorter value range) nor the ECQ-P polys from Banzai (same thing). The closest I come are the ECQ-V stacked metal film caps, the photos at the Digi-Key site looks close, but using the 1mf as a reference, the Panasonic data sheet says 7.3 x 8 x 11 mm (BxDxH), and I measure the GGG ones to approx. 6 x 6 x 8 mm.
Any hints appreciated.
Steinar
Rockin' in the Axis of Evil
Focalized
The Panasonic ones in the smallbear kit are those. The kit didn't have 105 caps. But i'm sure they are the same.
http://www.smallbearelec.com/Detail.bok?no=170
CodeMonk
Just an FYI kinda thing, I found this site helpful for caps.
http://www.muzique.com/schem/caps.htm
I recently tore apart one of my flangers (pawn shop special for about $25, its a Johnson flanger).
Its loaded with those caps.
Mich P
Hello they are Panasonic Stacked Metal Film Capacitors, V-Series.
You can find them here http://www.banzaieffects.com/Stacked-Metal-Film-c-1020.html
Mich P.
SolariEGO
Thanks for chippin' in guys!
All the Panasonic ECQ series look more or less identical (apart from size), and the (ECQ)V-series 50 stacked metal film caps are indeed the most compact I've come over on the net (and I've been through the data sheets at the Panasonic and Digi-Key sites), but the ones GGG ueses still seems smaller (as noted in my first post, approx. 6 x 6 x 8 mm for the 1mf cap, compared to the 7.3 x 8 x 11 mm in the V-series data sheet).
Ah, chuck it, size is in the eyes of the beholder, right?
Steinar
foxfire
have you tried asking them, GGG that is? i've never dealt with them but i hear they are pretty nice. rylan
ayayay!
The people who work for a living are now outnumbered by those who vote for a living.
SolariEGO
Foxfire: Sure, I've sent them an e-mail through their site, but haven't got a reply yet, so I thought I'd ask here.
ayayay!: Yeah, that's the V-series ones Mich P mentioned, and the ones I've found to be closest to the GGG ones, but they still seem a little bigger.
Steinar
SolariEGO
OK, mystery solved. Mich P and ayayay! were right all along - the 1 mFs are indeed the (ECQ) V-series 50 stacked metal film caps (even though the measurements don't add up in my head). Digi-Key has a great variety, if anybody else's into Panasonic chiclet type caps, I've found that the B-series 50V poly caps are the most compact and economical from the pico fahrad range 'till 0.047mF, and the V-series metal ones are the best choice between 0.068mF and 1mF.
Steinar
