Phase 100 rant, and question: TL022 = TL072 ?
Started by Praying_V, June 11, 2008, 11:43:08 AM
dschwartz
#20
now i´m confused!
i have been reading about opamps lately and i came to the conclusion that basically, they´re all the same. Its function is to add, substract and multiply... so..why do 1458´s work better than the other opamps?? iknow that the differences between opamps are:
- current consuption
- Input Impedance
- noise
- headroom (amplification vs rail voltage)
- slew rate
- Clipping shape
- other non-important ratings (Max V, Max I, dissipation, etc etc)
i know slew rate can affect high frecuencies..also clipping shape..
Is maybe the input impedance? is the opamp in a configurantion that the Input Z is set by the opamp itself? not using a Z resistor?
i have just got out of a discussion with a DIY friend that says that opamp type makes a huge difference.. i can´t believe that.. an opamp is an opamp!!! like a calculator is a calculator!!!
Tubes are overrated!!
http://www.simplifieramp.com
petemoore
huge difference..
  depends on your perspective I guess.
  Basically all opamps are the same.
  If you notice one sounds better in a certain application:
  Like TL062 cures clicking or pulsing..or has the current consumption you desire...
  Or a high current amp works cleaner say in your otherwise very clean compressor...
  Or you need all the headroom you can get @9v and use an opamp that does rail to rail performance...
  Stuff like that or;
  You notice that the certain different characteristic of the sound of certain opamp is less desirable than the other [what I guess means 'huge difference' to some]...
  'Standard or premium'...when a good opamp does what the specs say it should do...should work fine, I can't see why a phase 100 would have any super-special needs, to get it at least functioning somewhat normally...tick would be the one thing above I can think of that a low current OA might cure.
the recluse
My futurlec order came in today and I was able to pull the 4558s out of my GGG Phase 100 and replace them.  I ordered LM1458 but got HA17458s, it's a dual opamp, so...
Anyway, I recently put an HA17458 into my Screamer clone and notciced how much of a difference it made so I was hopeful.  The new opamps seem to bring the phase out a bit more on the 2 and 4 positions, but it's still not quite there for me.  I think my last resort is going to be dropping the value of the resistor that was replaced to prevent oscillation.  The stock value is 15K, the new value is 29K, so I have my fingers crossed that maybe a 22K will split the difference.
I will be building a phaseur fleur soon anyway, so this may end up being a moot point.
Praying_V
Just in case, don't forget to mess with the internal trimpot too.
the recluse
I've been playing with the trimmer, but it hasn't provided any drastic results.
When I first built it, I ended up sending it back to JD at GGG so that he could diagnose the oscillation issue.  He had been hearing about the problem from a few people that built the kit, but hadn't had the problem himself.  The fix was boosting the value of R1, which is now suggested in the instructions for the P100 project.
I hope reducing the value of the resistor does the trick.  We'll see...
axg20202
#25
I must have missed this thread. I have built the GGG P100 twice, the second one using the revised board (all new components too). Neither worked and both had the same issue of oscillation in certain switch positions. I gave up on it after many hours of debugging and stripped the boards of their components. It actually gave me great pleasure to bin the boards and move on. To date it is the only build (of many) I have not successfully completed. The question is, is this project actually verified? I think not.
EDIT: sorry, it seems it has been built successfully before. Perhaps it is a case where the required component value tolerances are such that normal variability in components makes it a bit pot luck whether it will work or not? Anyway, it was not fun!
DougH
When you are swapping op amps around, try just swapping out the LFO IC's and leave the TL072's for the all-pass filters. If that works, it tells you there is something quirky about the TL072 that will not allow it to work with this LFO circuit. If it's necessary to swap out the TL072's in the all-pass stages, I would think there should be a trim adjustment or something for the control element voltages to get the filters to sweep correctly.
I have a Phase 90 on the breadboard right now with the 4 all-pass stages and LFO implemented with TL072's and it works great. There are differences between the P90 and P100 LFO circuits which could explain it or it could be an interaction between the vactrols and all-pass stages that doesn't occur in the P90 with the JFET control elements.
You guys are making a great case for using IC sockets in op amp circuits though, something I adhere to religiously. :icon_wink:
axg20202
Quote from: DougH on July 15, 2008, 09:32:04 AM
Definitely. I do it for all ICs in all builds. Desoldering ICs is a PITA and the sockets cost pennies.
ilcaccillo
I'm also in the Phase 100 nightmare.
I had an MXR phase 100 that stoped working  some time ago. (now I now that problably was a burned vactrol)
I decided then to build a new one.
Everything works fine , except for mode 2 and 4 that have some distortions, can't figure out why.
if anyone could help , here is mu thread:
http://www.diystompboxes.com/smfforum/index.php?topic=73640.msg597554#msg597554
BTW the opamps used in the Dunlop Phase 100 were all TL062.
jsleep
I'd like to offer my deepest apologies to everyone who has had trouble with this P100 kit or building from the project on the site.   Specifying the TL072 ICs was a bad mistake on my part.  Also releasing such a complex kit with a PCB with no solder mask probably wasn't the best idea either.  There was actually a couple minor mistakes in the schematic, I have already fixed and reposted that.
I'm in the process of fixing the kit and project up.  We will be getting new PCBs in next week and the kits and PCB will be up for sale again as soon as they check out okay.
For those of you who had any kind of aggravation with the PCB or kit that you purchased from us, please email and I will do my best to make it up to each of you individually as is best for you.  We'll send you a complete new kit at no charge to any of you who bought the kit and had trouble with it.  To send email me, just go to the General Guitar Gadgets site Contact page.
Thanks,
JD Sleep
For great Stompbox projects visit http://www.generalguitargadgets.com
Tony Forestiere
JD Sleep...a stand-up guy. This has got to be the classiest group of folks in the net.  :icon_cool:
"Duct tape is like the Force. It has a light side and a dark side, and it holds the universe together." Carl Zwanzig
"Whoso neglects learning in his youth, loses the past and is dead for the future." Euripides
"Friends don't let friends use Windows." Me
ilcaccillo
JD,
thanks for posting in this thread.
I've sent you an email about my pedal, which I built with a board ordered from you.
It would be great that fixing those errors in the schematic could solve most of our problems.
Hope to hear from you soon
TS
koen
major bump to this thread  :)
What's the status of the GGG Phase 100 now, have all issues mentioned above been fixed? I'm looking to build a phaser (to replace my Ibanez PT9 which I don't like much), and the GGG Phase 100 seems like a affordable option.
Govmnt_Lacky
Quote from: koen on December 02, 2010, 11:56:05 AM
I recently (about 6 months ago) built the GGG Phase 100. I used the VTL5C3/2 vactrols and I socketed R1. Also, I cannot remember but I used either JRC4558Ds or TL072s for the dual op amps. I must say that the only complaint that I have is the POPPING that happens when I turn the rotary switch. I did not use the switch specified in the BOM from GGG and I dont plan on switching while playing so I guess it would fall under the acceptable nuisance category.
The pedal sounds good though. It is more subtle when compared to the Phase 90 in my ears. JD is spot on with his reference to "Shattered" by the Rolling Stones.
koen
Thanks for your reply. My main gripe with my current Ibanez pedal is that I find that it sounds too harsh, not very warm. I'm not looking for freakish sounds but more things like Shattered/Beast of Burden, Brian May (Keep Yourself Alive eg), Gilmour, etc.
How does the GGG 100 compare?
Govmnt_Lacky
Quote from: koen on December 02, 2010, 12:37:23 PM
It has been a good while since I have played it but I do remember that it has a subtle quality to it. Like I mentioned before, you can definitely get the "Shattered" sound from it!  ;D
Ashura
Hello everyone.
I am thinking of building this Phase 100 pedal, among others, and considering it to be very large, I decided to redesign the PCB in a single-sided version that fits in a 1590B box ( http://www.hammondmfg.com/pdf/1590B.pdf ).
I have the project practically ready (99%), done in DipTrace. I followed the specifications of GGG ( http://www.generalguitargadgets.com/effects-projects/phase-shifters/mxr-phase-100/), although I changed the layout of some trails so that everything would fit in a PCB minor (I'm afraid this may interfere with the operation of the circuit ... ?? ). I'm about to start buying the material to start the pedal.
I could see on this topic that there were problems with pedal construction in the year 2008 through 2010. I wonder if now, in the year 2018, or between the year 2008 and this year 2018, someone built this Phase 100 GGG pedal with success (?).
If anyone can tell me about your success in building this pedal with some detail, I would be very grateful, as this can help me to solve some possible problem that my version has, before I even start the construction. If this is helpful, I can post a image of my project here.
Thanks in advance to anyone who can help ...
StephenGiles
#37
 Here is the circuit for MXR 100 adapted for 15v operation which worked very well.
   https://www.dropbox.com/s/s7094b77suttrdr/MXR%20100%2015v.JPG?dl=0
Ashura
#38
Interesting, StephenGiles. Did you build this pedal? Would you have an image with greater resolution and clarity? It's a bit difficult to see the component descriptions. You could say something else about this version:
would this be the original MXR phase 100 vingate circuit?
Why was it used 15v power.
StephenGiles
#39
Quote from: Ashura on October 08, 2018, 01:07:07 PM
This was the work of a former editor of UK Elektor, who told me it worked very well up to line level. He specifically modified the circuit for 15v operation - because he could!!
