cheap multimeter with gain testing?
Started by fogwolf, June 16, 2008, 03:31:45 PM
fogwolf
I couldn't find the 9202 at Hosfelt - they only one they have now is $75. Anyone recommend a cheap DMM with gain testing for transistors?
Thanks.
rnfr
i just found this one the other day at amazon.   dirt cheap, not sure about the QC though.  didnt have any reviews last i checked.
http://www.amazon.com/exec/obidos/tg/detail/-/B000W472BE/ref=ord_cart_shr?%5Fencoding=UTF8&m=AD3LNW5KGKKO3&v=glance
Minion
Look on e-bay...I got on that measures practicly everything for under $20...It does, all the regular stuff (Volts,amps,resistance,temp,AC/DC) but also does Capacitance, Hfe,Diode , continuity and a whole bunch of other stuff that I can"t think of right now....
I"m sure you can find a suitable one for much cheaper than you are going to get a a store...
Cheers
Go to bed with itchy Bum , wake up with stinky finger !!
fogwolf
Thanks for the suggestions!
Quote from: Minion on June 16, 2008, 04:04:19 PM
Cheers
fogwolf
Found this one for dirt cheap:
http://www.thomasdistributingshop.com/Cen-Tech-7-Function-Multi-Tester_p_158-1335.html
Question about this one:
Mentions it tests capicitance - will this provide what I would need for building effects pedals and synth modules as far as testing capacitors goes? I've seen links somewhere on the site to stand-alone capacitance testers so I wasn't sure.
Cheers
It can measure capacitors up to 20uF so it will be fine for stompboxes.
The HFE measurement on multimeters is useful but you can only use it for silicon transistors, if you want to measure germanium transistors you need something like  R.G.s tester
fogwolf
Quote from: slacker on June 17, 2008, 04:22:11 PM
Mich P
darron
the local electronics shops always sell DMMs for like $5 with all the normal features, and very good tolerance. they have gain readings.
