dual valcaster question
Started by alcoloic, June 18, 2008, 11:21:29 AM
Renegadrian
#20
I added a new VERO version with that correction - it should work - Please check it out!!!
In the LAYOUT GALLERY search for TWINCASTER.
PS actually it's 2 layout, with and without the R1 at the beginning at the second stage.
alcoloic
hi everybody thanks for all the answers
yeah it's much better with the second r1
frequencycentral thank you ! you made me realise the wallwart i was using was only 200 ma !!!
i always use my fx with different sources (bass guitar synth sampler etc ) so i have already put two switch for mods ! if anyone has a suggestion
anyway thanks a lot everybody
Renegadrian
Quote from: alcoloic on June 23, 2008, 04:18:08 PM
So did you try with and without R1b having the right wall wart???
Try an R1 value of 100k for synths, and perhaps 5M to 10M for microphones, depending on the type. Try it and tell me your results!
mitzrecords
hi, just wondering if anyone else built this thing.
I just built single one and love it! but i wanna more gain. i wanna try this.
if you have pics or layout would be much appreciated to guide through and double check.
thanks bunch.
ps im so addicted to building pedal. i spent too much money on parts last three weeks :icon_wink:
Renegadrian
Quote from: mitzrecords on November 19, 2008, 01:15:06 AM
As I wrote above, In the LAYOUT GALLERY search for TWINCASTER.
mitzrecords
Quote from: Renegadrian on November 19, 2008, 07:22:19 AM
oops, sorry. got it!
thank you! :icon_redface:
kurtlives
Ive been playing with a design similar to this for the last two nights on the bread board. Getting great results...
Ditch the pots on the cathodes, no idea why you would want them on a cascading circuit like this. Instead I replaced them with 16K resistors, you could use lower values for more gain. I am also using a DIP switch to add a cathode bypass cap in parallel to those resistors, gain boost switch!
Anyways to add the gain control I am just adding a variable voltage divider between the two stages, essentially a volume control. Also between the two stages I added a tone stack.
Also with all these stages cascaded I needed to adjust the coupling networks. Cut most cap values in half. Also reduced the plate resistors value, more so in the first stage.
Also I have the heaters running at 12V regulated and the rest at 30V regulated. Sounds amazing, a good step up from 12V. Lots of tone, I dig.
My DIY site:
www.pdfelectronics.com
