4049 based non-dirt projects?
Started by awitee, June 29, 2008, 07:58:02 AM
awitee
what are some good non-dirt 4049 based pedals out there?
i searched and all i could find was dirt pedals and a tremolo.. are there others?
oldrocker
My favorite is the John Hollis Ultra Flanger.
gez
CGDARK
This circuit is not a pedal but is a good relay driver for latching relays but it can be used with any relay with little or no modification. This time the 4049 is used as a flip-flop.
http://www.geofex.com/tektips.htm
CG
Ben N
zeppelinchld
not pedal based but if your looking for an interesting 4049 project, how about a brain stimulator :P
http://www.hackcanada.com/homegrown/wetware/ces/ces_circuit_2.html#ebs_4069
awitee
Ben N
I assume the tremolo you meant was this one: http://www.generalguitargadgets.com/diagrams/catrmsc.gif?
BTW, Gerry, I'd love to see the EF section of that fuzz-wah of yours. Your hints were not enough for a dolt like me to reconstruct.
gez
Quote from: Ben N on June 30, 2008, 11:16:47 AM
Although I like it, the whole circuit needs a rework (it could be better designed, including the envelope follower).  I need to try some things out with my scope and don't have the time at the moment.  With any luck I'll get to tackle it in the Autumn.
tranceracer
stm
#10
What about a phaser?
Check the Pearl Phaser schem at the FIS.  The mystery IC4 is a CD4069UB.  I bet a CD4049UB would work instead, keeping in mind the pinouts are different!
http://www.freeinfosociety.com/electronics/schemview.php?id=577
awitee
yup thats the one :icon_biggrin:
StephenGiles
MXR Envelope Filter - watch for the different pinout, but it works.
awitee
do you have links? :icon_biggrin:
thx for the suggestions!!
the reason BTW is that i asked my sister to buy a cd4049, and she ended up buying 6 haha
i just thought id use it
gigimarga
awitee
so instead of the 4066 and 4069 i can use 4049s?
soulsonic
Quote from: stm on June 30, 2008, 02:03:47 PM
Yes - Exactly the kind of thing I was going to suggest!
On a side-note... can anyone explain how the inverters work in the circuit? They look like they are in the place of the variable resistance element, but how are they accomplishing the variable resistance? Is it simply a matter of using their output MOSFETs as the variable resistors? Ever since I reversed a Bad Stone, I'd been wondering about this.
StephenGiles
Quote from: awitee on July 01, 2008, 06:06:37 PM
No just for the 4069, the 4066 contains switches and must remain the same for the pulse width modulation to work.
awitee
ohhh okok ill try to look for that ic
  Funny, Great and Happy, super combination !
