Held High?
Started by MikeH, June 30, 2008, 03:35:56 PM
MikeH
An EHX hot tubes (non-tube version) schematic I found says in the notes that "pins 5 & 7 of IC2 (4049ube) are held high to inactivate unused inverters".  Does that mean they are connected to 9v+?  Or whatever v+ happens to be?  Is that a common EE term?
aron
That's what I remember. Tie it to V+.
Quote from: MikeH on June 30, 2008, 03:35:56 PM
Yes, it is. It means "connected permanently to a source of a logic "one" signal. In most logic, a higher voltage is a logic one, so it became "held high".
GibsonGM
Most likely +5V...lots of those chips can be toast over that voltage (if they are CMOS)...check the data sheet for max supply V
ClinchFX
Standard CMOS like the 4049 has a maximum supply of 15V, so tying it to 9V is OK.
Peter.
ClinchFX Hand Made Effects Pedals
http://www.clinchfx.com
