HEF****/HCF****=CD****?
Started by DWBH, July 02, 2008, 06:13:58 AM
DWBH
Yeah, does chips that are like HEF4049, or HCF4093, are the same thing as CD4049 and CD4093?
nelson
Datasheets are your friend. Datasheets ftw!
My project site
Winner of Mar 2009 FX-X
DWBH
#2
Indeed they are. Shame on me. Gonna have a look at 'em now...
The reason I posted here was because I thought they were like equivalents, I mean, European/American equivalents, like ECC83/12ax7, but that's just plain stupid.
JDoyle
Yeah. This one is kind of tricky. On the one hand it normally doesn't have much to do with American/Euro/Asian standards. On the other hand, it's worse.
First, with ICs, transistors are a whole 'nother matter, you are pretty safe to assume that a difference of only PREFIX simply denotes different makers (Suffix generally denotes package and/or selectivity within a part run; CA3080 vs. CA3080AE, for example; the latter has a tighter offset spead). This difference in prefix only, where the same part, generally a 'general-purpose' type, is made by two competeing manufacturers, is called 'second sourced' and is in fact a benefit to marketing the part because a potential customer, say the military, will know that if Company A folds, Company B will still make the chip that gets the $2B aircraft off the ground so they won't have to scrap an entire fighter wing over $1.39 of silicon.
In theory, they are supposed to be electrically the same chip. In theory. Best to get a couple and test one or two to make sure.
Second, the above works as a 'first guess' and is best to use only with the numbers you recognize. Even if you do recognize it there are a few more traps you could fall into. Besides the obvious 'Replacement' lines like ECG and NTE, there were at one point or another lines also from GE and RCA/(someone I don't remember) with the prefixes of GE and SK, respectively. Don't know about the GE chips but the SK ones don't match up to the 'real' numbers. Though sometimes they do - in the cases of their own original part numbers.
Which brings us back around to the best answer: look up the datasheet.
For me, the most comprehensive site is: www.datasheetarchive.com
It only allows 20 per day but it is thorough.
Regards,
Jay Doyle
DWBH
Thanks... it's just that I found a box that has like 20 chips. I never cared for them, because I only saw HEF and HCF, so nothing for me. However a couple of days ago I took that box out and began to read the rest of the IC codes :icon_lol:
Oh, these are actually useful.
So kids, read the whole code. Not just the first 3 letters.
StephenGiles
I think that by and large (translate that into Spanish!!!), a CD prefix will always do the job in effects circuits.
DWBH
QuoteCreo que en general, a CD prefix will always do the job in effects circuits.
Ah, much better  :icon_lol: :icon_lol:
Paul Perry (Frostwave)
The prefixes refer to different types of construction.
Which influences the power ratings, logic levels, speed of operation etc.
Read all about it here: http://en.wikipedia.org/wiki/Logic_family
